Vista display issues
Discussion in 'Windows OS and Software' started by Bog, Jan 6, 2007.
  1. vladvlad
    vladvlad Newbie
    hmmm. When installing the driver and choosing "Custom" the installation simply tells me that I have no installable components :-( . When on express, the installation completes, but my driver does not change.
    I have stretching on the wide screen of the laptop because the new driver does not install for some reason, and microsoft VGA driver isnt working properly: I cant set the resolution higher than 1024x768.
    What version of vista are you using (mine is Business 6000) ?
    When you go to display settings->advanced->properties->driver, what year and version of display driver does it show? Perhaps I could just find the driver somewhere.
    My laptop is also Toshiba A70,3.06GHz,1150MBram,60GB HDD@7200rpm, ATI Radeon IGP 128MB, 15.4" wide display. Thus I think that the driver should install on my system as well, but no luck :-(
    thanks for your help, I greatly appreciate it.
    Vlad
  2. Bog
    Bog Losing it...
    I uninstalled Vista Ultimate (ver. 6000 RTM) since I wouldn't use it as my primary OS of choice, but I don't remember the video driver version, in XP its version 6.14. Unfortunately I don't know why the driver worked only on my laptop so I can't offer you much help. My only advice is to wait for Vista to mature and hope that ATI writes new drivers designed specifically for the 9100 IGP, although I wouldn't get my hopes up. Even with the 9600's driver I experienced problems as my frame buffer was locked.
    PS; The main problem was that even at 1024x768 res, text and graphics looked a little unfocused; because of the standard VGA adapter, I'm sure. The graphics are the way they are because of M$'s driver IS working properly. If you did a fresh install of XP without the manufacturer's drivers, you'd get the same standard VGA adapter.
  3. vladvlad
    vladvlad Newbie
    :D LOL Can we exchange laptops ?
