Vista Battery life questions?
Discussion in 'Asus' started by SRD, Mar 16, 2007.
  1. SRD
    SRD Notebook Virtuoso
    I am thinking about installing Vista on a z35f. I have only used vista on my desktops. Is it true vista uses about 20 percent more battery life than XP with say CHC installed?
  2. Gautam
    Gautam election 2008 NBR Reviewer
    I don't think it's 20% more battery life consumed. In the beginning, before a lot of bugs were worked out, Vista would eat batteries. They did some reworking, and now, without Aero, you should get approximately the same battery life as in XP.
  3. gcrajan
    gcrajan Notebook Enthusiast
    According to some benchmarks ive found on other sites it shows vista as draining the battery a little bit more but definlty not 20%
  4. RogueMonk
    RogueMonk Notebook Deity
    I'm finding 10% more than XP.
  5. SRD
    but have you ever used CHC with XP with it underclocked?
  6. lenardg
    lenardg Notebook Evangelist NBR Reviewer
    I think when aero is off (by default when you use the battery saver profile in vista it turns aero off) it gets you the same values as XP.
  7. Insane
    Insane Notebook Evangelist
    well when idling its about the same, maybe 10%. But I've noticed that when i use it 'normally' its more like 20-30% less. its VERY noticable!
    And Notebook hardware controller doesnt work under Vista YET.
    Insane
  8. SRD
    Insane Are you disabling aero when on battery?
  9. ez2remember
    ez2remember Notebook Evangelist
    I noticed there is much more HDD activity in Vista so that may explain a little bit more drain than XP.
  10. lenardg
    I am guessing that would be superfetch or the defragmentation which is scheduled to run every week. At first I found this to be very disturbing, Vista doing things automatically without me knowing anything about it :confused:
