Virus Found. Help needed much.
Discussion in 'Security and Anti-Virus Software' started by jimmy-floyd, Mar 16, 2008.
  1. jimmy-floyd
    jimmy-floyd Notebook Evangelist
    I'm using Vista Firewall, ThreatFire and Avira Antivir.
    Yesterday i started a system scan with Avira, it has found 4 viruses, i moved them to quarantine, then removed. then i started a second scan and no viruses were found.
    Now i started BitDefender online scanner through IE, he started to update virus def. files but said that some updates failed. but i clicked an option to start scan anyway.
    Now it has made a half scan, and in statistics window it says that "At least one of the infected files could not be disinfected or deleted".
    I go into Detected problems section and there are: files with status "clean" and 3 other files in folder: Temporary internet files/Content.IE5 : one file with "deleted" status, but other file with "update failed" status and another one with "infected with: Troyan.Agent.AHDK".
    1. How could i delete these two viruses?
    2. As i understand they are more malware than viruses, but how could they got in my pc as i'm using triple secure system? but frankly - i have turned off Vista firewall for a day recently. maybe i should install Comodo with defense+ off ?
    Any Help appreciated.
  2. Lithus
    Lithus NBR Janitor
    1. Either use HijackThis and post the log on their website, or clean install.
    2. You downloaded something.
  3. swarmer
    swarmer beep beep
    IMO it is absolutely crucial to have some firewall in place -- either Windows Firewall or a 3rd party firewall -- at all times when you are connected to the internet or even a local network.
    Also... do you have UAC on or off? And Windows Update?
    If neither Avira nor BitDefender can get rid of all your Malware, I suggest a reinstall. System Restore may also be an option... but since you seem to have had a number of pests in there, I'd suggest reinstalling.
  4. flipfire
    flipfire Moderately Boss
    try a trojan remover.. if that doesnt work.. clean install
    watch what you download next time. Im suprised avira didnt catch this the moment you got/opened this virus.
  5. jimmy-floyd
    Lithus,
    Thanks, I'll try HijackThis.
    Yes, i downloaded and download a lot.
    swarmer,
    i have turned UAC off. Windows Update - it is on.
    flipfire
    trojan remover, ok, i'll google it.
    I downloaded and download a lot, especially different hd and sd trailers, teasers. I know that Avira has an option to check every downloaded file, but it would be inconvenient for me.
  6. jimmy-floyd
    Scanned with Troyan remover - no malicious files found.
    Here is the logfile of the scan with HiJackThis (i need someone competent to tell me what to fix):
    Logfile of Trend Micro HijackThis v2.0.2
    Scan saved at 14:06:00, on 17.03.2008
    Platform: Windows Vista (WinNT 6.00.1904)
    MSIE: Internet Explorer v7.00 (7.00.6000.16609)
    Boot mode: Normal
    Running processes:
    C:\Windows\System32\smss.exe
    C:\Windows\system32\csrss.exe
    C:\Windows\system32\wininit.exe
    C:\Windows\system32\services.exe
    C:\Windows\system32\lsass.exe
    C:\Windows\system32\lsm.exe
    C:\Windows\system32\winlogon.exe
    C:\Windows\system32\svchost.exe
    C:\Windows\System32\svchost.exe
    C:\Windows\system32\SLsvc.exe
    C:\Program Files\Protector Suite QL\upeksvr.exe
    C:\Windows\System32\spoolsv.exe
    C:\Program Files\Avira\AntiVir PersonalEdition Classic\avguard.exe
    C:\Windows\system32\taskeng.exe
    C:\Windows\system32\Dwm.exe
    C:\Program Files\Apoint\Apoint.exe
    C:\Program Files\Apoint\ApMsgFwd.exe
    C:\Program Files\sony\ISB Utility\ISBMgr.exe
    C:\Program Files\Avira\AntiVir PersonalEdition Classic\avgnt.exe
    C:\Program Files\ThreatFire\TFTray.exe
    C:\Windows\System32\rundll32.exe
    C:\Windows\System32\WDBtnMgr.exe
    C:\Program Files\Protector Suite QL\psqltray.exe
    C:\Program Files\SRS Labs\Audio Sandbox\SRSSSC.exe
    C:\Program Files\Griffin Technology\PowerMate\PowerMate.exe
    C:\Program Files\Apoint\Apntex.exe
    C:\Program Files\Avira\AntiVir PersonalEdition Classic\sched.exe
    C:\Program Files\Onlineeye\gmxffcsrv.exe
    C:\Program Files\Microsoft SQL Server\MSSQL.2\MSSQL\Binn\sqlservr.exe
    C:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\Binn\sqlservr.exe
    C:\Program Files\sony\Network Utility\NSUService.exe
    C:\Windows\system32\PnkBstrA.exe
    C:\Windows\system32\stacsv.exe
    C:\Program Files\ThreatFire\TFService.exe
    C:\Program Files\Toshiba\Bluetooth Toshiba Stack\TosBtSrv.exe
    C:\Program Files\sony\VAIO Event Service\VESMgr.exe
    C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VCSW\VCSW.exe
    C:\Windows\system32\DRIVERS\xaudio.exe
    C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzCdbSvc.exe
    C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzFw.exe
    C:\Program Files\sony\VAIO Event Service\VESMgrSub.exe
    C:\Program Files\Sony\VAIO Power Management\SPMgr.exe
    C:\Windows\system32\wuauclt.exe
    C:\Program Files\Mozilla Firefox\firefox.exe
    C:\Program Files\FlashGet\flashget.exe
    C:\Windows\system32\wbem\WmiApSrv.exe
    C:\Windows\explorer.exe
    C:\Program Files\Adobe\Reader 8.0\Reader\AcroRd32.exe
    C:\Windows\system32\conime.exe
    C:\Windows\System32\mobsync.exe
    C:\Windows\System32\mblctr.exe
    C:\Program Files\ABBYY Lingvo 12\Lingvo.exe
    C:\Program Files\ABBYY Lingvo 12\LvAgent.exe
    C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
    C:\Windows\system32\wbem\wmiprvse.exe
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.daemon-search.com/startpage
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.club-vaio.com
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
    R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
    O1 - Hosts: ::1 localhost
    O2 - BHO: Octh Class - {000123B4-9B42-4900-B3F7-F4B073EFC214} - C:\Program Files\Orbitdownloader\orbitcth.dll
    O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
    O2 - BHO: flashget urlcatch - {2F364306-AA45-47B5-9F9D-39A8B94E7EF7} - C:\Program Files\FlashGet\jccatch.dll
    O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0\bin\ssv.dll
    O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar2.dll
    O2 - BHO: FlashGet GetFlash Class - {F156768E-81EF-470C-9057-481BA8380DBA} - C:\Program Files\FlashGet\getflash.dll
    O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar2.dll
    O4 - HKLM\..\Run: [Apoint] C:\Program Files\Apoint\Apoint.exe
    O4 - HKLM\..\Run: [DRCU] "C:\Program Files\Sony\DRCU\DRCU.exe"
    O4 - HKLM\..\Run: [ISBMgr.exe] "C:\Program Files\Sony\ISB Utility\ISBMgr.exe"
    O4 - HKLM\..\Run: [PSQLLauncher] "C:\Program Files\Protector Suite QL\launcher.exe" /startup
    O4 - HKLM\..\Run: [avgnt] "C:\Program Files\Avira\AntiVir PersonalEdition Classic\avgnt.exe" /min
    O4 - HKLM\..\Run: [MAgent] C:\Program Files\Mail.Ru\Agent\MAgent.exe -LM
    O4 - HKLM\..\Run: [ThreatFire] C:\Program Files\ThreatFire\TFTray.exe
    O4 - HKLM\..\Run: [NvSvc] RUNDLL32.EXE C:\Windows\system32\nvsvc.dll,nvsvcStart
    O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\Windows\system32\NvCpl.dll,NvStartup
    O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\Windows\system32\NvMcTray.dll,NvTaskbarInit
    O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
    O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
    O4 - HKLM\..\Run: [WD Button Manager] WDBtnMgr.exe
    O4 - HKLM\..\Run: [VersionCheck] "C:\Program Files\Onlineeye\vcheck.exe"
    O4 - HKLM\..\Run: [MSConfig] "C:\Windows\system32\msconfig.exe" /auto
    O4 - HKLM\..\Run: [TrojanScanner] C:\Program Files\Trojan Remover\Trjscan.exe
    O4 - HKCU\..\Run: [SRS Audio Sandbox] "C:\Program Files\SRS Labs\Audio Sandbox\SRSSSC.exe" /hideme
    O4 - HKCU\..\Run: [PowerMate] C:\Program Files\Griffin Technology\PowerMate\PowerMate.exe
    O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'LOCAL SERVICE')
    O4 - HKUS\S-1-5-19\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter (User 'LOCAL SERVICE')
    O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'NETWORK SERVICE')
    O4 - Global Startup: WD Backup Monitor.lnk = C:\Program Files\My Book\WD Backup\uBBMonitor.exe
    O8 - Extra context menu item: &Download by Orbit - res://C:\Program Files\Orbitdownloader\orbitmxt.dll/201
    O8 - Extra context menu item: &Grab video by Orbit - res://C:\Program Files\Orbitdownloader\orbitmxt.dll/204
    O8 - Extra context menu item: &Закачать все при помощи FlashGet - C:\Program Files\FlashGet\jc_all.htm
    O8 - Extra context menu item: &Закачать при помощи FlashGet - C:\Program Files\FlashGet\jc_link.htm
    O8 - Extra context menu item: &Перевести с помощью ABBYY Lingvo... - res://C:\Program Files\ABBYY Lingvo 12\Lingvo.exe/3000
    O8 - Extra context menu item: &Экспорт в Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office12\EXCEL.EXE/3000
    O8 - Extra context menu item: Do&wnload selected by Orbit - res://C:\Program Files\Orbitdownloader\orbitmxt.dll/203
    O8 - Extra context menu item: Down&load all by Orbit - res://C:\Program Files\Orbitdownloader\orbitmxt.dll/202
    O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0\bin\npjpi160.dll
    O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0\bin\npjpi160.dll
    O9 - Extra button: Mail.Ru Агент - {7558B7E5-7B26-4201-BEDB-00D5FF534523} - C:\Program Files\Mail.Ru\Agent\magent.exe
    O9 - Extra 'Tools' menuitem: Mail.Ru Агент - {7558B7E5-7B26-4201-BEDB-00D5FF534523} - C:\Program Files\Mail.Ru\Agent\magent.exe
    O9 - Extra button: (no name) - {85d1f590-48f4-11d9-9669-0800200c9a66} - C:\Windows\bdoscandel.exe
    O9 - Extra 'Tools' menuitem: Uninstall BitDefender Online Scanner v8 - {85d1f590-48f4-11d9-9669-0800200c9a66} - C:\Windows\bdoscandel.exe
    O9 - Extra button: (no name) - {8DAE90AD-4583-4977-9DD4-4360F7A45C74} - (no file)
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\Office12\REFIEBAR.DLL
    O9 - Extra button: FlashGet - {D6E814A0-E0C5-11d4-8D29-0050BA6940E3} - C:\Program Files\FlashGet\FlashGet.exe
    O9 - Extra 'Tools' menuitem: FlashGet - {D6E814A0-E0C5-11d4-8D29-0050BA6940E3} - C:\Program Files\FlashGet\FlashGet.exe
    O13 - Gopher Prefix:
    O16 - DPF: {5D86DDB5-BDF9-441B-9E9E-D4730F4EE499} (BDSCANONLINE Control) - http://download.bitdefender.com/resources/scan8/oscan8.cab
    O23 - Service: AntiVir PersonalEdition Classic Scheduler (AntiVirScheduler) - Avira GmbH - C:\Program Files\Avira\AntiVir PersonalEdition Classic\sched.exe
    O23 - Service: AntiVir PersonalEdition Classic Guard (AntiVirService) - Avira GmbH - C:\Program Files\Avira\AntiVir PersonalEdition Classic\avguard.exe
    O23 - Service: Onlineeye Firewall Service (gmxfwsvc) - GMX - C:\Program Files\Onlineeye\gmxffcsrv.exe
    O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1150\Intel 32\IDriverT.exe
    O23 - Service: MSCSPTISRV - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AvLib\MSCSPTISRV.exe
    O23 - Service: NSUService - Sony Corporation - C:\Program Files\sony\Network Utility\NSUService.exe
    O23 - Service: PACSPTISVR - Unknown owner - C:\Program Files\Common Files\Sony Shared\AvLib\PACSPTISVR.exe
    O23 - Service: PnkBstrA - Unknown owner - C:\Windows\system32\PnkBstrA.exe
    O23 - Service: SonicStage Back-End Service - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AvLib\SsBeSvc.exe
    O23 - Service: Sony SPTI Service (SPTISRV) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AvLib\SPTISRV.exe
    O23 - Service: SonicStage SCSI Service (SSScsiSV) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AvLib\SSScsiSV.exe
    O23 - Service: SigmaTel Audio Service (STacSV) - SigmaTel, Inc. - C:\Windows\system32\stacsv.exe
    O23 - Service: ThreatFire - PC Tools - C:\Program Files\ThreatFire\TFService.exe
    O23 - Service: TOSHIBA Bluetooth Service - TOSHIBA CORPORATION - C:\Program Files\Toshiba\Bluetooth Toshiba Stack\TosBtSrv.exe
    O23 - Service: VAIO Entertainment TV Device Arbitration Service - Sony Corporation - C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCs\VzHardwareResourceManager\VzHardwareResourceManager.exe
    O23 - Service: VAIO Event Service - Sony Corporation - C:\Program Files\sony\VAIO Event Service\VESMgr.exe
    O23 - Service: VAIO Media Integrated Server (VAIOMediaPlatform-IntegratedServer-AppServer) - Sony Corporation - C:\Program Files\sony\VAIO Media Integrated Server\VMISrv.exe
    O23 - Service: VAIO Media Integrated Server (HTTP) (VAIOMediaPlatform-IntegratedServer-HTTP) - Sony Corporation - C:\Program Files\sony\VAIO Media Integrated Server\Platform\SV_Httpd.exe
    O23 - Service: VAIO Media Integrated Server (UPnP) (VAIOMediaPlatform-IntegratedServer-UPnP) - Sony Corporation - C:\Program Files\sony\VAIO Media Integrated Server\Platform\UPnPFramework.exe
    O23 - Service: VAIO Media Gateway Server (VAIOMediaPlatform-Mobile-Gateway) - Sony Corporation - C:\Program Files\sony\VAIO Media Integrated Server\Platform\VmGateway.exe
    O23 - Service: VAIO Media Content Collection (VAIOMediaPlatform-UCLS-AppServer) - Sony Corporation - C:\Program Files\sony\VAIO Media Integrated Server\UCLS.exe
    O23 - Service: VAIO Media Content Collection (HTTP) (VAIOMediaPlatform-UCLS-HTTP) - Sony Corporation - C:\Program Files\sony\VAIO Media Integrated Server\Platform\SV_Httpd.exe
    O23 - Service: VAIO Media Content Collection (UPnP) (VAIOMediaPlatform-UCLS-UPnP) - Sony Corporation - C:\Program Files\sony\VAIO Media Integrated Server\Platform\UPnPFramework.exe
    O23 - Service: VAIO Entertainment UPnP Client Adapter (Vcsw) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VCSW\VCSW.exe
    O23 - Service: VAIO Entertainment Database Service (VzCdbSvc) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzCdbSvc.exe
    O23 - Service: VAIO Entertainment File Import Service (VzFw) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzFw.exe
    O23 - Service: XAudioService - Conexant Systems, Inc. - C:\Windows\system32\DRIVERS\xaudio.exe
    End of file - 12812 bytes
  7. Softix
    Softix Notebook Enthusiast
    I think you should try hijack this and if ever you can used AVG And antivera I have been using both and I can say that it works fine with me. Last time I have some virus and antivera is very fast in blocking them.
  8. Leon
    Leon Notebook Deity
    Try SUPERantispyware. It should give you a clean system.
  9. bmwrob
    bmwrob Notebook Virtuoso
    I'd be very suspicious of Lingvo and Flash Get. I read somewhere (lost the link and now can't find it) that Flash Get can possibly show up as a false positive when using Avira.
  10. jimmy-floyd
    brkhobowriter
    i'll try.
    bmwrob,
    maybe it's what i wanted hear! cos, i also suspect flashget givining a false positive with Avira.
