Verizon 4G LTE Firmware update (MC7750)
Discussion in 'Panasonic' started by Rob, May 15, 2013.
  1. toughcook
    toughcook Newbie
    Showing 68a2. Not sure if it makes a difference, but it's XP. And was working although acting up prior to a modem replacement from Panasonic. Called them to ask for advice, but no luck. I have since reimaged so I at least have a blank slate to work. Auto-connect is critical to this so any help is appreciated.
  2. BaRRmaley
    BaRRmaley Notebook Deity
    Just copy connection's shortcut to your \Start Menu\Programs\Startup.
    My common method :)))
  3. canuckcam
    canuckcam Notebook Evangelist
    Go here: http://source.sierrawireless.com/resources/
    and search for your MC7750 - you'll be able to download firmware updates and the latest QMI driver and watcher.
    If you're running the FZ-G1A, why are you still on Windows XP? It comes with Windows 7 does it not? If not, an upgrade to Windows 8 is well worth it especially if you have an SSD.
    The Windows 8 integration with WWAN modems is great - and yes it will autoconnect on bootup. Plus with an SSD, the power-on to desktop time is >10 seconds on my mk5 CF-19 which is much closer to a tablet experience than XP on it right now!
  4. AJ Voicu
    AJ Voicu Newbie
    The MC7750 cards are no longer supported by VZN Network... :(
