VAIO S - PCI Simple Communications Controller
Discussion in 'VAIO / Sony' started by wii, Feb 23, 2010.
  1. wii
    wii IPS Rules
    I did a clean install, only missing is a:
    What is that? And where do I find it?
    Thanks
  2. H.A.L. 9000
    H.A.L. 9000 Occam's Chainsaw
    I'm going to guess it's your modem.
  3. wii
    wii IPS Rules
    I don't think the Vaio S even have a modem ?
  4. H.A.L. 9000
    What is your specific model number? And try *this*. That is for 32 and 64 bit.
  5. wii
    wii IPS Rules
    VPCS11X9E
    What is that download you suggested? The readme is very long:
    http://downloadmirror.intel.com/18494/eng/readme.txt
    Here are the device IDs:
    PCI\VEN_8086&DEV_3B64&SUBSYS_9069104D&REV_06
    PCI\VEN_8086&DEV_3B64&CC_078000
  6. H.A.L. 9000
    The download that I linked to is the Intel Chipset Driver update utility. And after seeing the hardware ID's that's the download that you need. And are you exactly sure that's the model number? That model number doesn't show up on the Sony support site.
  7. reb1
    reb1 Notebook Evangelist
  8. H.A.L. 9000
  9. wii
    wii IPS Rules
