Vaio Pro 13 Keyboard Backlight Problem (Windows 10)
Discussion in 'VAIO / Sony' started by k_gam, Sep 9, 2016.
  1. k_gam
    k_gam Notebook Enthusiast
  2. Somnio
    Somnio Notebook Consultant
    Hi! What is your version of VAIO Control center and the Firmware extension parser driver?
    Mine is:
    FEPD 8.0.2.5
    Shared Library: 6.1.0.02040
    Sony Control Center: 6.2.17.09140
    Those work for me, no issues at all.
  3. k_gam
    Hi,
    I have the exact same. I did a reset and installed the ones as yours but unfotunately the keyboard section is not there. is there a link to the Japanese Vaio control centre?
    Thanks
  4. Somnio
    Mmmm interesting. I have the option under "Input Device", just below "Touchpad Operations".
    Do you have that category?
    Also, check HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Plugins HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules, to see if KBDBacklightSetting is there.
    BTW, if anyone is still running Windows 8.1, could be interesting to have a .reg of this entire tree. I believe could be possible to enable features just messing with this.
  5. Somnio
    My reg dump for that entire section:
    Code:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center]
    "CurrentEPID"="EP0000296522"
    "INSTALLEDPATH"="@C:\\Program Files (x86)\\Sony\\VAIO Control Center\\VAIO Control Center.exe"
    "InstalledDir"="C:\\Program Files (x86)\\Sony\\VAIO Control Center"
    "MajorLineup"="13"
    "MinorLineup"="2"
    "SwitchControl"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\SwitchControl.dll"
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\6.2.0.04110]
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\6.2.17.09140]
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules]
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{049A70D9-212C-4DE5-9317-7C3BBFF92372}]
    "Module ID"="VESAppMon"
    "Enable"=dword:00000001
    "Description"="VESAppMon Module"
    "Param"=""
    "Trigger of loading"=dword:00000000
    "Order"=dword:e8000000
    "Flags"=dword:00000042
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{0C8BC06A-89E5-48ED-AD13-ED7D5E8616A6}]
    "Module ID"="VESCommonUI"
    "Description"="VESCommonUI Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{1ECF1E1F-4D29-4421-B10B-2D97A5B511BF}]
    "Module ID"="VESDisplayBrightness"
    "Description"="VESDisplayBrightness Module"
    "Param"=""
    "Flags"=dword:00000022
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{3020AE35-8C1E-4CDB-AFD9-C62928776A49}]
    "Module ID"="VESColorMgr"
    "Description"="VESColorMgr Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{3C05B95A-FCC4-4FA7-AB7C-C5E6B4FF2987}]
    "Module ID"="VESAutoDimmer2"
    "Description"="VESAutoDimmer2 Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{408416EA-AD0F-469E-A828-DC7ABC32B238}]
    "Module ID"="VESAdvancedStandby"
    "Description"="VESAdvancedStandby Module"
    "Param"=""
    "Flags"=dword:00000062
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{446DAFFC-5B88-498F-B4F7-1FCCB5D8BE54}]
    "Module ID"="VESSlateCtrl"
    "Description"="VESSlateCtrl Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{467681DA-B93A-4B89-830E-8170BB439243}]
    "Module ID"="VESSuEvent"
    "Description"="VESSuEvent Module"
    "Param"=""
    "Order"=dword:48000000
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{4DD466CF-462B-4E10-A278-72E6DE339EAE}]
    "Module ID"="VESUSBKeyboard"
    "Description"="VESUSBKeyboard Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{50A1A93D-48D2-4B7D-8B65-9ECC24348A5E}]
    "Module ID"="VESStorageProtect"
    "Description"="VESStorageProtect Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{52D0AE8B-190F-4E7A-B75A-3627DF014702}]
    "Module ID"="VESTransform"
    "Description"="VESTransform Module"
    "Param"=""
    "Order"=dword:88000000
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{722873DF-9C09-495F-80CD-A2F5DA1056B1}]
    "Module ID"="VESSoundEffect"
    "Description"="VESSoundEffect Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{7A6E76E6-1F57-475F-B092-B4C4CAC62A52}]
    "Module ID"="VESRemoteKey"
    "Description"="VESRemoteKey Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{90032DA0-9072-4ACA-AFE0-7197C0517131}]
    "Module ID"="VESSmartConnect"
    "Description"="VESSmartConnect Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{9A0213B8-D47F-4B89-AC14-00D486162D8F}]
    "Module ID"="VESPenWake"
    "Description"="VESPenWake Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{9F2742E2-D841-4850-ABB3-735D078576B1}]
    "Module ID"="VESPerform"
    "Description"="VESPerform Module"
    "Param"=""
    "Order"=dword:ca000000
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{B17F4E3D-1FE4-43AE-985C-A2FF293A8B84}]
    "Module ID"="VESNaked3DControl"
    "Description"="VESNaked3DControl Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{BECCACE1-D6AB-4F89-B229-25E90148CCB0}]
    "Module ID"="VESPerformanceSwitch"
    "Description"="VESPerformanceSwitch Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{C2942124-68FF-4534-AA6E-6588A720F323}]
    "Module ID"="VESBackup"
    "Description"="VESBackup Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{C365DCD7-84CC-4360-A0C4-B1215AC6323D}]
    "Module ID"="VESKBStatus"
    "Description"="VESKBStatus Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{CB9C3077-6591-40A4-8D2D-A483F313370E}]
    "Module ID"="VESWndMsg"
    "Description"="VESWndMsg Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Modules\{EC448C00-D739-4D1A-832B-18F4FF59B8BA}]
    "Module ID"="VESTVPC"
    "Description"="VESTVPC Module"
    "Param"=""
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Plugins]
    "PowerPlanSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\PowerPlanSetting.dll"
    "CPUFanSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\CPUFanSetting.dll"
    "BCFSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\BCFSetting.dll"
    "LidSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\LidSetting.dll"
    "RefreshRateSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\RefreshRateSetting.dll"
    "SCSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\SCSetting.dll"
    "LBHSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\LBHSetting.dll"
    "KBDBacklightSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\KBDBacklightSetting.dll"
    "PointingDeviceSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\PointingDeviceSetting.dll"
    "ClickPadSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\ClickPadSetting.dll"
    "PenWakeSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\PenWakeSetting.dll"
    "ColorModeSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\ColorModeSetting.dll"
    "RealitySetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\RealitySetting.dll"
    "DisplaySetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\DisplaySetting.dll"
    "SoundEffectSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\SoundEffectSetting.dll"
    "SoundSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\SoundSetting.dll"
    "HDDSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\HDDSetting.dll"
    "SpecialButtonSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\SpecialButtonSetting.dll"
    "BackupSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\BackupSetting.dll"
    "RapidWakeSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\RapidWakeSetting.dll"
    "USBChargeSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\USBChargeSetting.dll"
    "AutoBrightnessSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\AutoBrightnessSetting.dll"
    "HDMIDisplaySetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\HDMIDisplaySetting.dll"
    "NetworkSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\NetworkSetting.dll"
    "3DSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\3DSetting.dll"
    "VISetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\VISetting.dll"
    "BootManagerSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\BootManagerSetting.dll"
    "ShowAgainSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\ShowAgainSetting.dll"
    "DefaultSetting"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\DefaultSetting.dll"
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\SButton]
    "AppPath"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\SBMsg.exe"
    "Description"="S Button Message"
    "Trigger"=dword:00000100
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Settings]
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Settings\Network]
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Settings\Network\Profile]
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Settings\VESAutoDimmer2]
    "NewDCP1Nit"=dword:00000031
    "NewACP1Nit"=dword:00000058
    "NewP1Lux"=dword:00000019
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Settings\VESColorMgr]
    "ExternOutputShow"=dword:00000000
    [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sony Corporation\VAIO Control Center\Settings\VESPerform]
    "Information Sound"="C:\\Program Files (x86)\\Sony\\VAIO Control Center\\pi.wav"
