UX32vd wifi and BT upgrade
Discussion in 'Asus' started by i9o, Nov 25, 2020.
Tags:
Will it work?
  1. Yes
    0 vote(s)
    0.0%
  2. No
    1 vote(s)
    100.0%
  1. i9o
    i9o Newbie
    Dear Community,
    I want to upgrade the mini PCI-E network card in this old ultrabook. Looking at the space inside and taking some measurements, I am pretty sure I can fit an adapter for the new M.2 socket and a new AX200NGW WiFi6 with BT 5. There is also the newer AX210 with Wi-Fi 6E and BT 5.2 available. Prices are very reasonable, I just wonder whether it won't cause any conflict with other components. My system is W10 64 bit, so I won't have issues.
    Many thanks
  2. senso
    senso Notebook Deity
    You want the AX200, the AX201 doesn't use PCIe but CNVio and your laptop doesn't support that.
