Using two wireless adapters for twice the bandwidth?
Discussion in 'Networking and Wireless' started by RichBaines, Jan 5, 2008.
  1. RichBaines
    RichBaines Notebook Consultant
    Hi guys. Basically im using one wireless card and i get slight signal loss when playing online games. I have a spare usb wireless adapter, could it be possible to link both the adapters together to get twice the bandwidth?
  2. MaxPig
    MaxPig Newbie
    try bridging the two connections
  3. lixuelai
    lixuelai Notebook Virtuoso NBR Reviewer
    I dont think that is how bridging works. Bridging is used for sharing an internet connection.
  4. adinu
    adinu I pwn teh n00bs.
    That's not how connections work. If they did, then people would purchase 30 wireless cards and have 30 times the bandwidth...
    You're being limited by the distance you are from the router and the bandwidth limit of your ISP. Adding more wireless connections will not magically decrease the distance to your router and increase the bandwidth that your ISP is giving you.
    You want better bandwidth? Then go out and buy a better and faster connection and make sure that you are very close to the wireless router.
  5. {oroka}
    {oroka} Newbie
    That is not always the rule... you can use a bigger better antenna to increase your connection to the router. Some wireless nics now come with 3 antenna on one card (mostly 802.11n stuff).
    With a laptop you are somewhat limited for external antenna though. I have a second nic in my lappy and I will be installing a connection for a external antenna when I get the cable in the mail.
    I dont know of you can use 2 nics together, but I doubt it is impossible.
  6. blue68f100
    blue68f100 Notebook Virtuoso
    Want work, MS does not know how to optimize the use usage of 2 connections. MS will always use the 1st connection. Only time you can use 2 is ICS. Now some SMB routers can use 2 broadband connections with the options of load balancing or fallover.
  7. knightingmagic
    knightingmagic Notebook Deity
    It's not possible, sadly enough. It'd be awesome to use two in parallel, like ADSL.
  8. RichBaines
    Im not quite sure you understood what i meant. I probably should have explained my problem more clearly.
    My wireless router is downstairs (the only place where theres a phone line, its almost directly below me). I game on my desktop (has a wireless pci card). The speed of my ISP is fine (often d/l at 800kb/s :D ).
    When playing cs:s online for example every 30-60 seconds i'll lag. Which is rather annoying as i always get shot! I know its because of the wireless connection because ive run a very very long rj45 cable down to the router and its fine!
    Upon further investigation i downloaded net stumber to see what my signal strength was like. Signal strength was excellent, there was no noise but the signal would disappear for about 1 second every 30-60 seconds. So obviously this is the cause of my lag in cs:s, but im unsure why its doing it. Any idea's?
  9. NotebookYoozer
    NotebookYoozer Notebook Evangelist
    ideas? don't game on wireless
  10. RichBaines
    thanks for that suggestion (idiot). but its the only option i have. Anyone else?
