Using dell charger for HP laptop
Discussion in 'HP' started by sreenadh, Jul 24, 2008.
  1. sreenadh
    sreenadh Notebook Enthusiast
    My personal laptop is a HP Compaq nx6310. I usually forget to take my laptop's charger when i am taking it to work. Buying a new charger is pretty expense when i enquired. At work i have a dell laptop. I was wondering the dell charger instead of the hp's.
    In my charger:
    INPUT: 100-240V ~ 1.6A
    OUTPUT: 18.5V 3.5A
    Dell's charger:
    INPUT: 100-240 V ~1.5A
    OUTPUT: 19.5V 3.34A
    I know that there is a difference. But not sure if it can do any harm. Pls reply.
  2. f15hp
    f15hp Notebook Consultant
    It may not cause harm right away, but it might in the long run. I don't recomend using the Dell's charger on the HP laptop since watts might be different too.
  3. makaveli72
    makaveli72 Eat.My.Shorts
    watts alone?...this mixing of manufacturers should be a no-no rule...Especially w/ dell and hp connecting together like that...come on man...this should not be allowed! :eek:
  4. Greg
    Greg Notebook Nobel Laureate
    Even if it did work, I wouldn't trust it. Watts could be different, but either/or could have different tolerances of noise and feedback circuitry that could RUIN either part.
  5. 3mguy
    3mguy Newbie
    I would think after you run down your laptop battery a couple of times you would remember to take the charger to work with you.
  6. sjordi
    sjordi Notebook Geek NBR Reviewer
    I would not trust anything coming from Dell. Period.
  7. Badious
    Badious Notebook Enthusiast
    Technically it should be fine. Its lower watt lower amp which means it wont fry your battery. But it's not what the laptop was designed for so I wouldn't use it.
  8. sgip2000
    sgip2000 Notebook Consultant
    I'd be more concerned with the voltage difference than the watts.
