USB device not recognized!!
Discussion in 'Hardware Components and Aftermarket Upgrades' started by JSinglez, Apr 12, 2009.
  1. JSinglez
    JSinglez Notebook Enthusiast
    ok i dragged that usbstor.sys file into my windows folder, what should I do with it now?
  2. jackluo923
    jackluo923 Notebook Virtuoso
    Go to device manager and use that driver for your "unrecognized" hardware.
    This might make some USB storage device work.
    BTW.. forgot to mention.. have you checked if the hardware IDs of usb devices...etc are valid in device manger?
  3. Evolution
    Evolution Vox Sola
    Updating your bios is a fairly easy process. All you need is the current bios file from the acer euro FTP for the aspire 5100 series. I still have my aspire 5102 and I have talked many acer users through the bios flash process. Follow my post here and you will be okay [note the current Bios version is 3.13 and not 3.05 as it was at the time of that post]. Try the bios flash and see if it fixes your usb problem.
  4. JSinglez
    sorry for my confusion but how exactly do i select that as the driver for this device? I also do not see anything identified as a hardware ID
  5. JSinglez
    so the readme in the folder for 3.13 said
    BIOS Update from version 3.12 to 3.13 is only possible in DOS Mode
    should I be concerned about that? otherwise i just run the flash exe and it will do everything automatically?
  6. Evolution
    Evolution Vox Sola
    What Bios version are you currently on? You can check by using CPU-z.
  7. JSinglez
    ahh it says im only on version 2.73
    i suppose I will be fine to just run the exe then! i will do that now and let you know how it goes
  8. JSinglez
    ok I have successfully flashed the bios, but my USB ports still do not work :(
  9. JSinglez
    ok turns out im an idiot and didnt notice that there IS in fact already a usbstor.sys in my system 32 folder... :\
    also: every time I try to update the drivers or select that driver for use with the "unknown device" it just tells me that my drivers are up to date for the device.
  10. stevezachtech
    stevezachtech Notebook Evangelist
    This is usually a motherboard driver problem, get the latest driver for your motherboard and things should be working well with your USB.
