USB controllers- Unknown Device
Discussion in 'ASUS Gaming Notebook Forum' started by Valour549, Jun 2, 2011.
  1. Valour549
    Valour549 Notebook Guru
    I'm using an Asus G53SW-A1, with the three USB 2.0 and one USB 3.0
    Ever since i received my laptop, everytime I turn it on I get this "USB Unknown Device" pop up on the system tray. I go to Device Manager and I can see it there too, the details in Properties are:
    Unknown Device
    Device type: Universal Serial Bus controllers
    Manufacturer: (Standard USB HostController)
    Device status: Windows has stopped this device because it has reported problems. (Code 43)
    Now the funny thing is there isnt even ANY device inserted!!!!
    On top of that, all four USB ports work fine (I tried them all).
    1) I have installed all the drivers for my laptop model from the Asus website, still didn't help. My BIOS is up to date as well.
    2) Using 'update driver software' yields 'the latest driver has been installed'.
    3) I can disable or uninstall it. But on the next startup it pops up again! This time the system tray ballon message gives something along the lines of "Device failed to install." I guess the system auto installs it on start-up.
    Any ideas? It's quite frustrating to have that thing pop everytime on start-up when in fact all the USBs are working fine.
    Many thanks in advance!!! I have attached a screen shot if it helps.
      File size:
      122.5 KB
      1,889
  2. Chastity
    Try resetting you BIOS to defaults, plus update your Intel INF.
  3. manu72
    manu72 Notebook Consultant
    Properties on device, details, property --> Hardware Ids. You can find out the pci\ven info - something like PCI\VEN_xxxx&DEV_xxxx
    Google that and most probably you will find out what device is.
  4. Valour549
    @ Chasity: My BIOS is default; and I have updated my Intel INF Driver from the Asus site as i previously mentioned.
    @ manu72: I've tried looking at that before, all it shows is "USB\UNKNOWN"
    Please help!!!
    EDIT: I've also updated my INF Driver from the site mentioned in this thread but still no luck: http://forum.notebookreview.com/asu...rivers-everything-you-need-fresh-install.html
    EDIT 2: After updating the INF Driver and the USB 3.0 Driver from the above thread, the popup no longer occurs upon startup. The Unknown Device however, still remains in the Device Manager, and cannot be permanently disabled/uninstalled (ie. reappears after reboot).
      File size:
      157.7 KB
      2,424
  5. bigspin
    bigspin My Kind Of Place
    Did you installed your camera driver? Where's the imaging device?
  6. Valour549
    Camera driver?
  7. bigspin
    Yep! there's a driver for camera device (Web Cam)
  8. Valour549
  9. tijo
    tijo Sacred Blame Super Moderator
    You should have an imaging device in your device manager and it doesn't seem to be there. It's connected via internal USB too so that might just be your problem.
    Here's a screen of my device manager: [​IMG]
  10. bigspin
    Try the G53JW driver . For me it's Chicony
    Yeah! that's what i'm thinking as well.
