USB 3.0 Problem - Toughbook CF-31 - MK2 - Core i7 2640m
Discussion in 'Panasonic' started by ToughBreaK, Feb 8, 2018.
Core i7 2640m vs Core i5 3320m - What would you choose?
  1. Core i7 2640m
    1 vote(s)
    100.0%
  2. Core i5 3320m
    0 vote(s)
    0.0%
  1. ToughBreaK
    ToughBreaK Notebook Enthusiast
    I keep pushing the envelope and finally I ran into a brick wall.
    I took a risk and bought 16GB of ram and it worked. But I couldn't stop there.
    I wanted a DVD-RW drive and USB 3.0.
    So what did I do? I bought a CF-31 i5 3320M and gutted it.
    I took out the USB 3.0 PCB from the i5 and installed it into the i7 MK2, after all, Panasonic's website had USB 3.0 drivers for the i7 MK2.
    I tested the USB 3.0 in the i5 and it worked great on Windows 7, however after I installed the USB 3.0 PCB in the i7 MK2 and ran the recommended driver, I receive an error when I click on the installed USB 3.0 Host Controller Utility, "USB 3.0 Host Controller not found". I tried all the Intel drivers, various i7 2640 & Sandy Bridge USB 3.0 drivers from Dell, Lenovo, Toshiba, Asus. Nothing seems to work most are the same driver actually (Renesas).
    I tried to install the driver that worked on the i5 running Win7 and on the i7 MK2 running Win7 and I get an error "This computer does not meet the minimum requirement for installing the software."
    All the USB ports work with USB 2.0 drives. Ironically my USB 3.0 external HDD isn't recognized when I plug it into the USB 3.0 port but does recognize when I plug it into the other 3 USB 2.0 ports.
    Is this a lost cause? I thought the USB 3.0 PCB was a factory upgrade when buying the i7 MK2, thus a driver available on the Panasonic website.
    Any advice would be MUCH appreciated. BTW, love the site, long time user, first time poster.
  2. Shawn
    Please post a photo of the CF 31 mk2 i7 BIOS main page.
    USB was an option for the mk2.
    From a quick look at my parts, The board with the blue USB 3.0 port is just the physical port.
    The 3.0 port needs a 3.0 controller chip. That would be on the motherboard.
    I am guessing the mk2 USB 3.0 units had a different motherboard.
  3. toughasnails
    I don't own a 31 but I thought the 31 MK2 was only a i3 or i5 .
    Please post the full model numbers of the 31's
    Dannemand likes this.
  4. User32
    User32 Notebook Deity
    USB3 on a 31 Mk2? I thought only the Mk3's had USB3?
  5. Shawn
    USB 3.0 was an option on a mk2. Read the fine print in my attached image under options
    Bob Johnson has mk2 i7s advertised. But I canb not find mk2 i7 listed anywhere else.
    toughasnails likes this.
  6. User32
    Interesting, sounds like what Lenovo did with the X220 i7 models, they had 1 USB3 port replacing a USB2 port.
  7. ToughBreaK
    That's going to be a bummer if the motherboard isn't compatible. I was trying my best to make the ideal poor man's rig. Hopefully my idea doesn't come to a crashing halt. Here's the BIOS screen, do you think a BIOS update may help? However, I couldn't find any CF-31 MK2 firmware update info anywhere.
  8. Shawn
    here.
  9. Shawn
    No USB I/O chip on the board that has the ports on it.
    Sorry
  10. ToughBreaK
    Well ya live and learn. Too bad really, its pretty powerful for it's age.
