USB 3.0 not working on my ASUS G74SX A2
Discussion in 'ASUS Gaming Notebook Forum' started by fermanagh, Aug 6, 2011.
  1. fermanagh
    fermanagh Notebook Enthusiast
    Sorry it took so long to get back on this post but USB 3.0 is still not working...
    I installed that USB Charge app but it doesn't even launch! I can see it in the task bar and see the icon ASUS Ai charger but clicking on it does nothing, and killing the task and restarting it does nothing either.
    For info, I'm running Windows 7 64 bit
    Yep, all USB 2.0 devices work perfectly when connected to the USB 3.0 port. If I connect my 3.0 device into the 2.0 hub it works fine.
  2. Chastity
    Go into your BIOS, and go to the 2nd tab. You should see an entry for USB CHARGE. Please enable this. This does the same as the AI Charger application.
    Case: 1584769
  3. FlyingFalcon
    FlyingFalcon Notebook Evangelist
    I have a G53JW. I own a WD Passport and Samsung M2, both of which connects with the usb3.0 port to my computer perfectly well. But i tried connecting my friend's Samsung M2 usb3.0 hard disk via usb3.0 and my computer refuses to read it but my computer detects it as being connected because the led on the hard disk lights up and my computer makes the sound that plays when an external device is connected. It works on the usb2.0 port perfectly fine. What could the problem be?
  4. MRZEN
    MRZEN Newbie
    I have the same problem on my UX31 ultrabook. Did you perhaps upgrade Windows 7 to the ultimate edition?
  5. fermanagh
    Hello there,
    I installed the app and then enabled the setting in the BIOS. I still have the same issue as before...
  6. Chastity
  7. FlyingFalcon
    Hi people
    I just bought a Seagate 1.5tb usb3.0 portable hard disk because my WD MyPassport got screwed. I got it yesterday. I had plugged it into my usb3.0 port and the thing worked fine. I copied 250GB stuff from my internal hard disk to the Seagate and it did it very fast. Then disconnected the thing.
    Today, I tried connecting it to my USB3.0 port and it simply will not recognise my external. I connect it to the usb2.0 port and it works fine. Tried restarting but to no avail.
    Is there anything I can do to get it working on my usb3.0 port. I cannot find a powered cable here in Kerala, India. The AiCharge thing does not work on my laptop for some reason.
    ANy help will be appreciated.
    Regards,
    Vipin
  8. kimiraikkonen
    kimiraikkonen Notebook Evangelist
    Hi Vipin,
    I noticed G53JW has a BIOS update called "210" version here and its release note only contains "Update USB 3.0" which may be a fix against intermittent USB 3.0 connections. Thanks to Asus for providing non-brief explanation about release notes, though!:mad:
  9. fermanagh
    Hi there, I successfully installed the updated version of the app this time and pushed it all the way to 99%. The 3.0 port still won't recognize my WD passport drive! I even went out and bought a 4 port powered USB 3.0 hub and it won't even accept the connection from my drive...?
    Any ideas Chastity?
  10. Wolfpup
    Wolfpup Notebook Prophet
    For the record, my G74's USB 3.0 port has always worked fine, with just the single driver for it downloaded from Asus' site. I've used it with two different USB 3.0 Seagate external drives, and then used a Tripp Lite USB 3.0 powered switch, which worked great too.
    Speeds really are much better...probably a minimum of twice as fast as 2.0 on my hard drives, and quite often 4x as fast.
    (My G74's keyboard went wacky I guess after I cleaned it, so now it's sitting under my desk running Folding @ Home on my CPU and GPU 24/7! It's doing THAT really well too so far :) )
