USA Versions vs UK Versions
Discussion in 'HP' started by soday, Feb 28, 2018.
  1. soday
    soday Newbie
    Hi,
    I am looking at getting an envy 13 in the UK.
    The current version available in the UK is 13-ad015na but in the US it is the 13t.
    The main differences are the US one has 8th Gen Processor but lacks the dedicated graphics card (with option to get a 4k display.
    As I will be installing Linux and for my use the newer processor is the better option than the graphics card (and I'd like the choice to upgrade to 4k display)
    Does anyone know if HP are likely to release this version in the UK (based on past experience) and if so when is it likely to be?
    Thanks,
    S
Similar Threads - Versions Versions
  1. Aurumnus
    219
