Upgrading Razer Blade Pro 2017 Gtx 1060 17.3 inch FHD to QHD Screen
Discussion in 'Razer' started by drystxx, Jul 29, 2019.
  1. drystxx
    drystxx Notebook Guru
    Hello everyone
    I cracked my original Razer Blade pro 2017 17.3 LCD screen which has FHD resolution and 120hz. (original part number AUO B173HAN01.6)
    I plan to swap it with a 17.3 LCD screen with QHD Resolution and 120hz (part number is AUO B173QTN01.0 17.3)
    My question is will upgrading my razer blade pro to qhd screen work? both screens are from the same manufacturer (AUO) and they are both EDP 40 pins.
    http://www.panelook.com/B173QTN01.0_AUO_17.3_LCM_overview_30300.html
    http://www.panelook.com/B173HAN01.6_AUO_17.3_LCM_overview_35469.html
    Thanks in advance.
    rb6freak likes this.
  2. Amelyssa
    Amelyssa Newbie
    Sorry to resurrect, but did you end up going through with the upgrade?
  3. drystxx
    Hi thanks for the follow up. Yeah it did work! however I couldn't control the brightness via hardware so I used a software to adjust it.
    alaskajoel likes this.
