Upgrades for my p770zm-G
Discussion in 'Hardware Components and Aftermarket Upgrades' started by egypticus, Jan 14, 2018.
  1. egypticus
    egypticus Notebook Enthusiast
    Hi all,
    I bought a laptop from pcspecialist here in the UK and it came with the following specs:
    Operating System
    Windows 10 Home 64-bit
    CPU
    Intel Core i3 4170 @ 3.70GHz 50 °C
    Haswell 22nm Technology
    RAM
    12.0GB Dual-Channel DDR3 @ 798MHz (11-11-11-28)
    Motherboard
    Clevo P770ZM-G (SOCKET 0)
    Graphics
    Generic PnP Monitor (1920x1080@75Hz)
    2047MB NVIDIA GeForce GTX 970M (CLEVO/KAPOK Computer) 47 °C
    Storage
    465GB TOSHIBA MQ01ABF050 (SATA) 28 °C
    Optical Drives
    No optical disk drives detected
    Audio
    Realtek High Definition Audio
    (Specs were taken from speccy program)
    I am wondering if i can upgrade my processor to an i7 decent enough for gaming and possibly the graphics card to a nvidia gtx 980m.
    I have seen on youtube other people with these setups on the same p770zm_g motherboard, but after emailing pcspecialist they said the motherboard cant handle an i7 processor...... this confused me.
    I opened the laptop up and it has a desktop cpu, which i presume means it can be upgraded.
    I am lost at this point and require someone with better knowledge than myself and pcspecialist to clear things up for me.
  2. sicily428
    sicily428 Donuts!! :)
  3. egypticus
    ah yes the 4790 was the one i was ready to purchase, thats great..
    sorry whats an edp panel?
  4. sicily428
    check with aida64 extreme what is ypir panel display.
    scenario1: it is an edp panel----->you can upgrade with a pascal card like gtx1060 or gtx1070
    scenario2: it is an lvds panel----->you can upgrade with a gtx980m
  5. egypticus
    This is what it looks like if that helps. I believe it' the option 2 but I'm not 100%
  6. sicily428
    Use Aida64 extreme or HWinfo for checking the panel display
  7. egypticus
    Field Value
    Monitor Properties
    Serial Number None
    Pixel Density 128 ppi
    Picture Aspect Ratio 16:9
    Monitor Type 17.3" LCD (FHD)
    Monitor Name LG Philips LP173WF4-SPD1
    Monitor ID LGD046C
    Model LP173WF4-SPD1
    Maximum Resolution 1920 x 1080
    Max. Visible Display Size 382 mm x 215 mm (17.3")
    Manufacturer LG Display
    Manufacture Date 2014
    Gamma 2.20
    DPMS Mode Support None
    Supported Video Modes
    1920 x 1080 Pixel Clock: 173.32 MHz
    Monitor Manufacturer
    Product Information http://www.lg.com/us/monitors
    Driver Update http://www.aida64.com/driver-updates
    Driver Download http://www.lg.com/us/support
    Company Name LG Electronics
    Is this what you are referring to?
    I cannot see anywhere where it tells me specifically what type of panel it is, if your asking about the screen/display
    sicily428 likes this.
  8. egypticus
    if you want me to paste any other info from them two programs you suggested i can.
  9. sicily428
  10. egypticus
    thank you for your help.
    So a i7 4790 and a gtx 1070 pascal card would be a decent setup?
