Upgrade VGA from GTX 460M to GTX 980M
Discussion in 'Alienware M15x' started by DNOYA, Jul 8, 2018.
  1. DNOYA
    DNOYA Notebook Guru
    HI All,
    Greetings,
    I have an alienware M15X with the following specifications:
    - Alienaware M15X R2 2010
    - VGA GTX 460M
    - 16GB of RAM
    - Processor i7 7740QM
    - Windows 10
    - PSU Originil
    my Question :
    can i upgrade the my VGA GTX 460M to GTX 980M without any big modification (just flug and play) : as a link below
    could anyone also advice the SOP to install.
    https://www.ebay.com/itm/NVIDIA-GTX...296022?hash=item467f96bd56:g:5~0AAOSwgslbKkal
    Pls need your advice, once i got the conclution will order the VGA on eBay and instal to my AW and post the update in this Group.
    Thanks for all
    Brs
    DN
  2. King of Interns
    King of Interns Simply a laptop enthusiast
    I would recommend upgrading to a 970M. You save your self money while the card thermally is a much better fit for the M15x. I have run a 980M in the past and I wasn't happy with the experience. 970M users on the other hand have been very happy.
    To go in more detail it was very hard to stop thermal throttling with the 980M as it put out much more heat than the M15x heatsink is designed to cope with. Even with an undervolt. The same experience is to be had with the older 880M.
  3. nforce4max
    nforce4max Notebook Geek
    The only thing I don't like about the 970m other than the drivers is the VRMs on these cards is they will burn if neglected or worse abused, just look at all the burned cards that pop up on eBay on a almost regular bases. Quadro M4000M interests me but is not cheap either but a few people here have used them and they are nice cards plus extra memory bandwidth and better VRM.
  4. ssj92
    ssj92 Neutron Star
    I don't know about that. I had a 970M in my Clevo P570WM and overclocked the crap out of it without any issues.
  5. DNOYA
    DNOYA Notebook Guru
    Hi Bro Thanks for the recommendation, I did check on eBay.. is really difficult to find GTX 970M some of the sellers, sell it with almost the same price with GTX 980M even more expensive. from Aliexpress is same case GTX880M also has almost the same price with GTX980M. only GTX 780M quite lowest 980M.
    GTX 780M
    https://www.aliexpress.com/item/GTX...52cb-499a-bca0-0efdab22e3c3&priceBeautifyAB=0
    GTX 980M
    https://www.aliexpress.com/item/New...f5b6-46cc-8a78-ef89764ccd52&priceBeautifyAB=0
    GTX 970M
    https://www.aliexpress.com/item/GTX...8d88-413d-8d04-1ecb964f3ef7&priceBeautifyAB=0
    how do you think if i upgrade with GTX 780M? all the serries with 80 it has 256 bit bus i think is really strong enought to play game release in 2016 - 2017 right?
    again need your advide and experince
    thanks soo much.
  6. nforce4max
    I think that you are better off just buying the 980 for reasons that you can re-use the card in a newer machine later and Kepler like Fermi drivers are going to be an issue where performance degrades due to lack of optimization then eventually support is dropped. 780 and 880Ms run Hot and a 980 is likely to run cooler but with the puny cooler in the M15x underclocking is likely needed depending on ambient temperature however you can improve it slightly with a modded vbios.
  7. nforce4max
    Well you more than likely made sure that there was not going to be an issue unlike oems and other users. I have also seen a fair number of burned 1070s.
  8. ssj92
    ssj92 Neutron Star
    Huh? Your original post said 970M, now you're saying 1070. 970M was reliable but 1070 is not. Only the MSI 1070 is reliable.
  9. DNOYA
    DNOYA Notebook Guru
    ehm..completely agree with you i will start order next month and start the Projejct. i hope nothing much to modified and just easy to install because i not soo familiar with
    laptop.
    thanks for the suggestion.
  10. nforce4max
    Don't mean to be an ass but why did make it out like it was all one thought when clearly the mention about the 1070 was something off on the side, don't understand why modern people struggle with language like this so no one can put anything off on the side anymore. I guess that I must be too old or something...
    Grant B Gibson likes this.
