Upgrade to 120Hz panel in Y520...possible?
Discussion in 'Lenovo' started by genexis_x, Apr 15, 2018.
  1. t456
    Both and no; profiles are applied to the monitor driver. See here for some background and a quick-use tool.
    Run through these great diy calibration pages and see whether you can fix things with a little tweaking of the display settings. Seems like gamma is too high ('white saturation' page), but the red may actually be correct. Most displays have a hard time there, so that's the getting-used-to-a-good-display bit. If the dark-red to bright-red transition is all visible, each band is distinguishable and steps are evenly spaced then that's really how it ought to look. It's just that most of us have never seen such colours on a monitor before, so it may appear a bit alien at first.
    pi4a7a likes this.
