Upgrade P870KM1- 60Hz to 120Hz QHD - What's required?
Discussion in 'Sager and Clevo' started by cope123abc, Sep 22, 2019.
  1. cope123abc
    cope123abc Notebook Evangelist
    Hi guys, to go from a 60Hz to a 120HZ QHD, do i simply need a replacement screen ?
    Will the EDP cable be okay to use?
    Also to carry out the procedure, is it a case of simply removing the screen bezel and swapping them over
  2. bennyg
    bennyg Notebook Virtuoso
    cope123abc likes this.
  3. cope123abc
  4. DaMafiaGamer
    DaMafiaGamer Notebook Deity
    Yes @bennyg is correct. A 1440p 120hz screen will work ONLY on a 4 lane 40 pin edp connector as it takes up the same bandwidth as the 4k panel...
  5. DaMafiaGamer
    However there is a certain 1080p 144hz panel that can work on 30 pin with degraded colour reproduction. (Basically looks like trash compared to a normal 1080p panel)
  6. cope123abc
    Okay thanks guys - appreciate this !!
  7. Meaker@Sager
    It's a pain to swap out the cable but possible.
  8. DaMafiaGamer
    Yeah it's the heap ton of screws that discourage me :D
    Otherwise its fairly simple to open.
  9. Meaker@Sager
    Generally the easiest way is to sort them into the pattern they go in on each layer and take pictures as you go.
  10. cope123abc
    thanks guys apprciate the replies - wasn't for me, but for somebody externally asking :)
