Upgrade MSI GT73 SLI
Discussion in 'MSI' started by tataddd, Nov 24, 2021.
  1. tataddd
    tataddd Notebook Enthusiast
    Yes you are right, it's will cost nearly the same, BUT i sure you understand the challenge?
  2. tataddd
    About the TDP tweak i readed 3 time the post, I'm afraid to do it, it's often the problem, i make 1 to 1 the tutorial but at the end it don't work
  3. NeXt3R
    NeXt3R Notebook Evangelist
    challenge ?? SLI is **** .,,.and gtx1080 still old for modern games
    this not helps .,.,tune up what have "need only time + skill"
    or new notebook - RTX 30xx
  4. tataddd
    :D I heard a lots of people saying sli is ****!
    I check the new msi laptop and saw no more mwm... I'm so disappointed
  5. NeXt3R
    must use compatible HWprogramer ! must read full first page :D
    and on GT73 + EC mod "when draw to much power" ,,..,this reduce CPU
    try bench writen above and send results " i will send my config"
    1070 still works good :) but modern games need - half/sync 60fps target here
    or full support for g-sync
    and cpu - static "4GHZ" or more and all works smooth ;)
  6. NeXt3R
    my is similar gt75 + 7820hk + 1070
    your is identical .,,.try bench and determine your performance state
    use maintenance or OC - similar like my results
    upgrade i think not have benefits ! or new notebook is better "but not THIN notebook !!"
  7. NeXt3R
  8. Reciever
    Reciever D! For Dragon!
    MSi GTX 1080 doesnt need power cable. Running one in my P750FM right now.
    MSi 1070 is very capable if you grab a programmer and adjust the TDP parameters.
    Still playing my games as desired, only cyberpunk 2077 needed to be tweaked everything else I play so far hasnt had much issue.
    Deep Rock Galactic, Days Gone, Horizon Zero Dawn, Dragon Quest IX are what have been in my rotation lately.
    While I am happy with my GTX 1080 for now, I also had the MSi 1070 in my Alienware 17 R1 and was very happy with its performance after flashing and tuning, a lot of performance left on the table. That all being said, be sure to do your homework and take precaution while you go through it. Its not difficult but doesnt mean you shouldnt understand the process.
    EDIT: SLI is dead so dont bother with that.
  9. NeXt3R
    i think on MSI need ?? CLEVO is using special pin in MXM
    or old revision have thin 6pin in right corner for 180W stable tdp
    //example
  10. NeXt3R
    and what would happen to solder this power cable on the GTX 1070 :D ??
    edit //Reciever
    please what kind of hwprogramator did you use and everything worked as original?
    or must mod drivers for this modded vbios
    I am planning flash my 1070 but hard find in this country normal HWprogramer ,.,.ch341a + 1.8V is possitible find easy .,,.but this not works well ???
    ,..,next is EC on MSI .,,when i raise D-gpu this kill my CPU OC probarly :confused:
    and slot maximum capability "heavy long usage" 150W max or is safe from slot 200W+??
