Upgrade Firmware ME Alienware 17 R5/R1 Ranger
Discussion in 'Alienware 17 and M17x' started by Striker1234, Dec 11, 2017.
  1. Striker1234
    Striker1234 Notebook Consultant
    Intel Management Engine Introduction:
    Built into many Intel-based platforms is a small, low power computer subsystem called the Intel Management Engine (Intel ME). This can perform various tasks while the system is booting, running or sleeping. It operates independently from the main CPU, BIOS & OS but can interact with them if needed. The ME is responsible for many parts of an Intel-based system. Such functionality extends, but it's not limited, to Platform Clocks Control (ICC), Thermal Monitoring, Fan Control, Power Management, Overclocking, Silicon Workaround (resolves silicon bugs which would have otherwise required a new cpu stepping), Identity Protection Technology, Boot Guard, Rapid Start Technology, Smart Connect Technology, Sensor Hub Controller (ISHC), Active Management Technology (AMT), Small Business Advantage (SBA), Wireless Display, PlayReady, Protected Video/Audio Path etc. For certain advanced/corporate features (AMT, SBA etc) the ME uses an out-of-band (OOB) network interface to perform functions even when the system is powered down, the OS and/or hard drivers are non-functional etc. Thus it is essential for it to be operational in order for the platform to be working properly, no matter if the advanced/corporate features are available or not.​
    About Intel MEI Drivers
    The latest v11.7 drivers are usable with all Intel chipsets from 8-Series & up.
    More Information: (https://www.win-raid.com/t596f39-Intel-Management-Engine-Drivers-Firmware-amp-System-Tools.html)
    This is the thread where I upload the file (http://forum.notebookreview.com/threads/brainstorming-aw17-r1-ranger-r5-modifications.811433/), and I think is the way to go, but since ME is something important and usually forgotten by users, I decided to do its own thread...
    Alienware 17 R5/R1 ME Firmware Instructions:
    Lastest (9.1.37.1002) Intel ME Firmware Installer and Driver for Windows 10.
    Instructions:
    1.- Open CMD with ADMIN RIGHTS.
    2.- Unzip the Firmware on C:\
    3.- Go to C:\ on the CMD previously opened.
    4.- Run the "flash.bat" file on the CMD, wait the flash to finish.
    5.- Turn off and turn it on again (I prefer this over restart).
    6.- Check your BIOS Information.
    7.- Uninstall Intel Management Engine in Control Panel.
    8.- Uninstall Driver Intel Management Engine Interface.
    9.- Install the Driver for the Intel Management Engine Interface in the folder.
    Ondfritz likes this.
  2. Striker1234
    There is a higher version of ME for 8 Series:
    Intel ME 10.0 1.5MB Firmware v10.0.55.3000
    But since our AW17 did not come with ME 10 as base, I do not want to try it until I get an EEPROM programmer in case of need it.
    Is anyone able to try it?, any guinea pig?
    @javers @TheReciever @Ashtrix @EepoSaurus
  3. TheReciever
    TheReciever D! For Dragon!
    I think javers mentioned having an eeprom programmer and might be suitable for this. I wouldnt be surprised if Ashtrix or Eeposaurus had one either lol
    Sadly, I am not one of them lol but I was curious about this when I updated mine to the version you uploaded
  4. EepoSaurus
    EepoSaurus Notebook Evangelist
    Functionally speaking what benefit might this be?
  5. Strigae
    Strigae Notebook Enthusiast
    "Warning for 8-series systems: The 8-series desktop systems initially come with v9.0 firmware. The latter is upgradeable to v9.1 firmware (initially comes with 9-series desktop systems) only if the OEM has updated the BIOS to be compatible as well. If your BIOS is up to date and the firmware is still v9.0 then do NOT update to v9.1 but only to latter v9.0 releases."
    My system came with 9.0.
  6. Striker1234
    Our system too, but several system are capable to use 9.1 even the manufacturer did not release the upgrade in the BIOS.
    I tried in my AW and it works.
    (Im wondering about trying the ME 10 versión, but this is a risk for who do not have an eeprom programmer.)
    EDIT NOTE:
    ME 10 is for Broadwell no Haswell
  7. Striker1234
    ME firmware contains different modules : AMT(Active Management Technology), ASF (Alert Standard Format), QST (Quiet System Technology) and TPM (Trusted Platform Module) for hardware remotely management… but it also contains chipset’s settings (clocks, frequencies,...) which affect important parameters as BCLK, RAM, Turbo Boost, fans speeds…
  8. javers
    javers Notebook Guru
    Yeh no problem I should be able to give this a try. Probably be a week or two before I get a change as Christmas parties getting in the way of Alienware time atm :p
    Javers
  9. Striker1234
    ME 10 is only for Broadwell, according this sheet, the higher version we can use should be 9.5.60.1952
    You can try it with this one.
    Note: Please run MEManuf in order to check the 9.5 is running without problems
    "MEManufWin64.exe -verbose"
    Link of the Tools needed:
    http://www.mediafire.com/file/1865f0qbzo20bkc/Intel+ME+System+Tools+v9.5+r4.rar
    Firmware:
    https://www.mediafire.com/file/fl1g3oodiu9qhyu/Intel+ME+Firmware+v9.5.60.1952+(1.5MB).rar
    Thanks for your help on this @javers
  10. Strigae
    BCLK and fan control working properly with 9.1?
  11. Striker1234
    I dont have any problem at all!
    If you want me to perform some tests, let me know.
  12. dake8899
    dake8899 Newbie
    What is support for intel 8 chipset series, like Z87
