Understanding GPS Viewer
Discussion in 'Panasonic' started by toughasnails, Aug 13, 2019.
  1. toughasnails
    Trying to get my GPS up and running on my new to me CF-19MK5 . I installed GPS Viewer. Set com to "3" and baud rate to 4800 and click start GPS. Press 'Hot start" I get "3 blue" and '10 red" . On "Cold start I get "12 red and no blue but get 5 in a red box , top line ??
    I am using an old GPS from a MK2. Hopefully will pick up something new soon.
  2. evenflow153
    evenflow153 Notebook Evangelist
    Might be either a Serial issue or it being a MK2 one. The GPS from the older isn’t really being a issue
  3. Shawn
    Blair,
    Are you outdoors?
  4. toughasnails
    Yes and a nice clear sky. It's the same indoors just a couple less sats.
  5. mklym
    mklym Notebook Evangelist
    Try setting the viewer to comm2.
    evenflow153 likes this.
  6. toughasnails
    Did a search in GPS Viewer and found it on com3 only and also com3 in MS streets and trips
  7. mklym
    I fired up the U1 w/XP and S&T2013 and had the program scan for the gps. Found it on comm2. I guess it doesn't matter what comm port as long as the program finds the gps.
    Locked on 4 sats immediately, now has locked onto 2 more, indoors sitting at the kitchen table w/no windows close by.
  8. toughasnails
    2013 MS Streets and trips finds my location no problem. I will try it out later when I have my truck back
  9. Shawn
    Just for the fun of it, try 9600 baud
    Maybe the antenna is bad or not grounded properly.
  10. toughasnails
    Nope.... nothing on 9600. It's works now on MS Streets & Trips. So does anyone know what the red , blue and red box stands for in GPS Viewer?
