Under 3000€, reliable, high cores, quality - for work
Discussion in 'What Notebook Should I Buy?' started by AlphaScorpii, Jun 11, 2020.
  1. AlphaScorpii
    AlphaScorpii Notebook Enthusiast
    1) What is your budget?
    3000€
    17.3 but might go with smaller
    3) Which country will you buying this notebook?
    a. Like:
    Asus, Dell
    not sure
    Many application at once, 1 application that profits from big thread count and one from SSD speed
    Mostly plugged in, don't care about portability
    8) Will you be playing games on your notebook? (If so, please state which games or types of games?)
    no
    Not important
    Can't see
    11) What OS do you prefer? Windows, Mac OS, Linux, Chrome OS, etc.
    Windows
    12) What screen resolution(s) would you prefer? (See further below for explanations.)
    Not sure.. I guess I wouldn't use much 4k even if I had it as my scaling needs to be @100%
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (See further below for explanations.)
    Not important
    yes
    15) How much hard drive space do you need?
    1tb+
    16) When are you buying this laptop?
    Before october
    17) How long do you expect to use this laptop?
    Many years
    18) How long could you afford to do without your laptop if it were to fail?
    none
    19) Would you be willing to pay significantly extra for on-site warranty, or would it be acceptable to you to have to ship the laptop to the vendor for repair with perhaps a week or more outage?
    Probably will be buying laptop outside of my country so prefer no problems :)
    I will be buying new laptop in next few months and need something reliable as I use laptop for work. Need at least 12 threads (prefer 16), good build quality, good keyboard (prefer silver but not many options there). Prefer 17 screen but could go with smaller like Asus zephyrus G14.
    I had asus for the last 7years and no problems so they are my no1 pick a long with alienware R2/R3 (mostly because of white keyboard).
    Noise is important to me.. wouldn't prefer loud laptop. Aero 17 was one of my picks but I read it has coil whine.
    Razer blade 17 pro is one of the picks but I am not sure how reliable razer is.
    What would you suggest depending on my needs?
  2. alittleteapot
    alittleteapot Notebook Guru
    I have a recommendation:
    https://www.dell.com/en-us/work/sho...rationid=3946f008-cce1-464b-b355-699b46791300
    I myself have a Precision 7730. If you look at the support forum thread here for the Precision 7730, it's starting to push 300 pages - the Dell Precision support community is both knowledgeable, helpful, and love to push the envelope on their hardware. The 7750 is now available, but if you look at the performance specifications for the Intel series processors, there's virtually no difference in performance between the two generations. So, you save money on the 7740 and still get a very beautiful workstation class laptop. I purposefully do not include a large SSD in this configuration - I would buy an aftermarket Pro-class NVMe drive, for example an EVO Plus 2 TB NVMe drive, and you will save a LOT of money as opposed to buying directly from Dell. On my own 7730, installing a new NVMe drive takes about 3 screws, and I have four of these NVMe slots if I need more down the line.
    Also, Dell ProSupport gives you the ability to get real engineers on the line, and they will really send engineers to your home to fix things if necessary - it is very much worth the upgrade. My experiences with them have been very positive.
    This has a black keyboard, but I find it very usable.
