Unable to remove Power Meter from the Taskbar
Discussion in 'Windows OS and Software' started by wobble987, Jan 28, 2013.
  1. wobble987
    wobble987 Notebook Virtuoso
    Safe mode does nothing... what should i be doing there anyway?[
    QUOTE=JOSEA;9069764]If there is nothing in local settings do you have a recent restore point you can go back to?[/QUOTE]
    no... i disable that right after i first installed the OS... long time ago...
    no...
    is there a way to just do a fresh one?
    iirc there is a repair tool somewhere... i think it might have been under the windows install disc or something... can't remember what its called.. will that work?
    i guess what i need to do currently is to rebuild the registry. anyway to do that?
  2. radji
    radji Farewell, Solenya...
    Gimme a bit and I will break out my backup laptop and go to that registry key and copy the registry entry that controls it (provided I can locate it). If I can find it I will export it and PM it over to you. Other than that, the only option is to do a clean install.
    WARNINGWARNINGWARNINGWARNING I Am Not Responsible For Any Adverse Effects From Editing Your Registry! You have been warned!
    EDIT: Power configuration settings are in the HKEY_CURRENT_USER\Control Panel\PowerCfg\GlobalPowerPolicy
    Check the Policies entry. The 4th to last number on the bottom hex value should read 15, try changing it to 14. This is what changes in my power policy when I uncheck the "show power icon in taskbar". Restart and see if it works.
  3. radji
    See my above post for a possible fix.
  4. wobble987
    nice try... doesn't work though :(
    it revert back to 15 (power meter showing again) after i log back on/restart.
  5. wobble987
    tried uninstalling/reinstalling a bunch of program that might affect the registry.. its seems to be fixed now.
    YAY! :D
  6. radji
    Well at least you know what registry entry to change next time it happens.
