Unable to remove Power Meter from the Taskbar
Discussion in 'Windows OS and Software' started by wobble987, Jan 28, 2013.
  1. wobble987
    wobble987 Notebook Virtuoso
    I'm referring to the anomalies that i posted here:
    http://forum.notebookreview.com/win...-software-wiped-out-registry.html#post9056734
    Basically my problem now is that I am still unable to remove the "power meter" from the taskbar.
    I'm able to uncheck the "always show icon on the taskbar". which will remove the icon.
    however, the next time i logon/restart the computer; the power meter is showing up again.
    any idea what is wrong?
    how do i make windows 'remember' the setting?
    what is the relevant registry entry for this settings (in regedit?)?
    OS is XP SP3
  2. Primes
    Primes Notebook Deity
    did you right click on that power icon and see if there are any other options?
    the only other thing i can think of is maybe MS powertoys "tweakUI" has an option to disable that, but i cant remember:
    Windows XP downloads - Microsoft Windows
  3. wobble987
    i have tweakUI.
    i have already tried 'repairing' everything under the repair section.
    where is the option to disable the power meter?
    iirc, there is no option that would say turn off permanently by right clicking on the icon. only open. but i will check when i get the chance.
  4. wobble987
    anyone happens to know where the registry entry for "power meter" is located?
  5. JOSEA
    JOSEA NONE
    Have you run MSconfig and checked startup tab?
  6. radji
    radji Farewell, Solenya...
    Have you tried going into safe mode and unchecking the "always show icon on the taskbar" in the power options control panel?
  7. wobble987
    will that make any difference (by going into safe mode)?
    in any case, i will do definitely try that...
    in just a moment.
  8. wobble987
    seems like i'am missing:
    HKEY_CURRENT_USER\Software\Classes\Local Settings\
  9. JOSEA
    JOSEA NONE
    If there is nothing in local settings do you have a recent restore point you can go back to?
  10. radji
    If nothing's in that sub folder, then there's quite a bit missing. Have you backed up your registry before?
