UK laptop purchaser needs some help
Discussion in 'What Notebook Should I Buy?' started by NotVeryTechie, Jan 6, 2017.
  1. NotVeryTechie
    NotVeryTechie Notebook Geek
    I tend to do research on new tech to the extent that it prevents me actually buying the thing! I am hoping someone can help me narrow down my choices so that I can just get it done! My current computer is falling apart one thing at a time and I really need to get this resolved now. Just can't decide ... :)
    Here are my answers to the questions:
    General Questions – NOTE: I am in the UK
    1) What is your budget? £700, but would prefer to spend less than that.
    d. Mainstream; 15" - 16" screen, or e. Desktop Replacement; 17"+ screen
    United Kingdom
    a. Like:
    b. Dislike: Do not want a Mac
    No
    Email, Internet, watching films, Photoshop editing, video editing
    Mostly on my desk
    I don’t play much, only a very old ‘90s game and I don’t know if that can work on the new machines! (Caesar III)
    I usually plug in, so not vital, but if using away from the desk at least a few hours would be good.
    Don’t mind buying online
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, etc.
    Windows (not prefer – more like all my programmes are Windows-based)
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    Midrange, or possibly Maximum
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Glossy
    I would prefer a graphics card.
    Build Quality and Design
    Not the most important thing
    As soon as I can make a decision (I am not quick!)
    My last one managed 10 years, so I hope it will last a while
    Notebook Components
    I need at least 2TB
    Yes, DVD burner – possibly blu-ray
    Other
    I have the laptop on a coffee table, which is not hugely comfortable, so I generally hoist it onto my lap when I am watching stuff. It shouldn’t be too heavy.
    I also hate brushing the track pad when I type, so an easy on/off of the trackpad would be lovely.
  2. John Ratsey
    Notebooks with optical drives are becoming rare. Here are a few with DVD burners. Most people make do with a £20 external burner connected to a USB port. It's even rarer to find a notebook with a 2TB HDD. You may need to budget on getting a notebook with a small HDD and then doing a DIY upgrade to 2TB or consider having no more than 1TB internal used in conjunction with a portable HDD (which is cheaper than the bare HDD).
    I would also recommend paying attention to the display quality and viewing angles. The cheaper notebooks tend to use low quality 1366 x 768 resolution panels. Spending a bit more on a 1920 x 1080 resolution display with good viewing angles (many reviews include photos to illustrate this aspect) gets around the problem of having to tilt the display to get the right colour rendering and contrast and avoid any reflections.
    John
  3. NotVeryTechie
    Thank you! I will put those into the plan.
  4. John Ratsey
    My other comment is to point out that you can get some good deals at Dell Outlet. All the outlet stock comes with the same warranty as new products and, unless sold as "Scratch and Dent", will be like new (eg returned or cancelled orders). Pricing is typically 60% of Dell's normal prices plus there are discount coupons (currently 20% off everything but there's nothing I can find worth recommending as a lot of stock has been bought). Look at both the Home (Inspiron) and Business (Latitude) notebooks. The business notebooks have an on-site warranty.
    John
  5. NotVeryTechie
    Thank you so much, John. That is a top tip!
  6. StormJumper
    StormJumper Notebook Virtuoso
    I myself have disdain for ext OD unless one is desperate for it then they should look for a unit with OD refurbished or new that come with OD-they still exist one just has to do some looking.
  7. Galm
    Can you like... Rewrite this? It's pretty confusing. What is ext OD?
  8. NotVeryTechie
    I think it means Optical Device, and I would agree that I would much prefer an internal one rather than an external.
  9. Galm
    I know, it was more for others than myself. As long as you understand it it's fine.
