uCode fix for Spectre, HT bug fix and Meltdown.
Discussion in 'Notebook Dummy Guide Articles' started by THEBOSS619, Jun 29, 2017.
  1. THEBOSS619
    THEBOSS619 Notebook Guru
    I was going to say that to you but @inm8#2 got it first
    I will put a notice about it as we speak now.
    Edit:- Post is updated now :)
    Vasudev and inm8#2 like this.
  2. THEBOSS619
    I just wanted to point out something here :) and please if you see that I'm wrong correct me then... after all I'm human :)
    If you see the difference on performance [before the Spectre & Meltdown thingy events] then I'm sure that it will have effect changes on security too same as performance changes :)
    I would like to add another thing is I tried to make it load as early as possible by doing this trick :)
    Open the registry and go to [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\cpumcupdate] look at the [Start] key... usually you will find the value will be (2) [Which means Automatic] so... change it to (1) [Which means it will load with the system] :)
    I tried to put (0) [Which means it will load at boot] but it didn't work and it failed to apply the new microcode.
    tiliarou and Vasudev like this.
  3. Danishblunt
    Danishblunt Notebook Deity
    I checked my system and can't seem to get OS support to true, the registry fixes should enable it but for some reason it doesn't, any ideas why?
    Still running like a champ, better than ever, maybe AW related?
  4. saturnotaku
    saturnotaku Notebook Prophet
    I tried the automated patch on my MSI 16L13 with the i7 7700K, and while it applied properly, it causes Windows Explorer to behave strangely when I connect a USB drive. ESET NOD32 recognizes it, and I get the popup asking if I want to scan the drive. However, the prompt that usually comes up from Windows itself does not. The drive is accessible and usable in Explorer, but it won't eject when I initiate the command to do so. Uninstalling the patch reverts everything back to normal.
    Edit: After applying the registry fix noted here, everything seems to be working normally.
    THEBOSS619 and Vasudev like this.
  5. Vasudev
    Vasudev Notebook Prophet
    Thanks for the tip I'll try. I tried adding uCodes to InsydeFlash BIOS but the flashing refused to flash it saying Insecure Image and refused to flash.
    There are some performance decrease and I felt Win 10 mitigated that decrease using some portion of RAM as a result I did see W10 consumed less RAM.
    THEBOSS619 likes this.
