Ubuntu 11.10 on 16GB USB Flash
Discussion in 'Linux Compatibility and Software' started by Nemix77, Jan 12, 2012.
  1. Nemix77
    Nemix77 Notebook Deity
    Would a 16GB USB Flash be big enough for a Ubuntu 11.10 32-Bit installation?
  2. masterchef341
    masterchef341 The guy from The Notebook
    yes.
    the recommended minimum size is slightly under 16 GB.
  3. Nemix77
    So should I get a 16GB or 32GB USB 3.0 Flash drive if I want to be able to upgrade to 12.04 LTS in a couple months?
    I'm only using the OS as an emergency backup OS if I have no other full blown OS that's working. So basically, just Ubuntu 11.10 (12.04 LTS) + 3GB swap and some software; no games or media files.
  4. debguy
    debguy rip dmr
    You can get Ubuntu (and every other Debian-based distribution) on a 2GB stick. It just depends on what you install.
  5. Nemix77
    I want the Gnome interface and not interested in XFCE or any other Linux distros.
  6. Primes
    Primes Notebook Deity
    imo, 16gb is kind of overkill for a flash drive (even when running with persistence). I use a 4gb for distro testing, and even with installing additional software on it I never come close to filling it up. the only reason i could think of needing that much space is if you plan on putting lots of documents or music on it. In that case you might want to partition it so you have a separate area for your files because of the way persistence works.
  7. masterchef341
    should be fine on 16 easily
  8. Nemix77
    That's with 3GB swap and the possibility of upgrading to 12.04 LTS right?
    I just want to make sure it fits on 16GB with at least 5GB or more to spare other wise I'd grab a 32GB USB 3.0 Flash drive anything smaller then 16GB does no take advantage of USB 3.0 speeds.
  9. v1k1ng1001
    v1k1ng1001 Notebook Deity
    I suggest a class 6+ 16gb+ sdhc card that you can just leave in your computer.
  10. Nemix77
