TwoFingerScroll (two finger scrolling done right! + more)
Discussion in 'HP' started by MacHater, Feb 2, 2011.
  1. hacked
    hacked Newbie
    Hi machater
    awesome mod, two finger scrolling is vertically smooth, though only on internet explorer 9 [not firefox]
    my horizontal scrolling doesnt work at all, when i use both fingers to scroll, motion is locked to be vertical only. any ideas?
    i have synaptics driver doing everything except scrolling of any kind
    Thanks!
  2. justinkw1
    justinkw1 Notebook Virtuoso
    Did you try to enable and disable horizontal and vertical scrolling using the conventional method, through the Mouse Control Panel? Open the Mouse Control Panel, then go to the Device Settings tab, and select the "Settings..." button. This should open a new window, which has options to enable and disable the different types of scrolling available.
  3. YukonRon
    YukonRon Newbie
    How do I download the latest version? The link in your first post goes to the TabletPC Review page but I just get a header and logo on a blank page. If I go to your Project Homepage, I only see up to v1.0.6. there. How do I get v1.0.8? Is the problem with my IE8 browser?
  4. fakenjones
    fakenjones Notebook Enthusiast
    Here you go
  5. lOblivionl
    lOblivionl Newbie
    I couldn't install this mod. It says:
    Class not registered, ClassID:
    (9c042297-D1CD-4F0D-B1AB-9F48AD6A6DFF)
    Help! thanks.
  6. lOblivionl
    lOblivionl Newbie
    Finally got it to work, just had to restart since I just did a fresh install of win 7 ultimate. Testing it right now.
  7. Larrondo
    Larrondo Notebook Guru
    Yeah, this is what I'm getting. I tried restarting/re-downloading with no luck. I'm not sure what I'm doing wrong. I'm running Windows 7 64. Any suggestions? Thanks in advance.
  8. Larrondo
    I have seriously failed to install this. I just get the class not registered error. I've installed other programs with no problem at all. Not sure what to do.
  9. Larrondo
    OK-- had to update Synaptics driver. Then it worked fine. Looks great. Thanks.
  10. DoomCastle
    DoomCastle Notebook Enthusiast
    @MacHater: are you planning to publish the source code for this mod? I'd love to add and share a couple of features and fix a few bugs I've come across:
    - feature: option to invert scrolling direction
    - feature: edge motion for two-finger scrolling
    - feature: scrolling decceleration / inertial scrolling
    - bugfix: behavior of diagonal scrolling with acceleration enabled
    - bugfix: scrolling can stop when changing direction quickly (instead of moving towards the other direction).
    It would be great if I could start from your up-to-date version rather than the old v1.0.6 from google code. The less duplication the better!
