TwoFingerScroll (two finger scrolling done right! + more)
Discussion in 'HP' started by MacHater, Feb 2, 2011.
  1. 1k9
    1k9 Notebook Consultant
    I loaded the .7 version and when I used my left click on the pad my pointer would jump away. I had to unload it , it was driving me nuts.
  2. MacHater
    MacHater Notebook Evangelist
    Could you describe exactly how you left-clicked?
    Like, how many fingers were on the touchpad at the time prior to the click, etc.
    And did you disable Synaptics' "MultiTouch Gestures" in the control panel yet?
  3. aBs0lut3z33r0
    aBs0lut3z33r0 Notebook Consultant
    when using One+one tap for middle button ,the cursor jumps a little . is this a issue with synaptics driver version or TFS
  4. MacHater
    Original author of TwoFingerScroll implemented that specific feature.
  5. MacHater
    Version 1.08 released!
    - Added horizontal two finger scrolling
    - Added checkboxes to allow disabling/enable vertical & horizontal scrolling individually
    - Improved upon original implementation of edge scrolling
    - New ability to scroll horizontally while vertically edge scrolling, and vice versa
    - Various GUI tweaks
    - Fixed a jumping cursor bug with original author's implementation of one+one, and two+one click
    - Fixed a jumping cursor scrolling bug with vertical scrolling
    Use download link in original post!
  6. 1k9
    If I was touching the touch pad at all and used the left click on the touch pad the pointer would jump away
  7. MacHater
    I've fixed that in v1.0.8 (released).
  8. justinkw1
    justinkw1 Notebook Virtuoso
    Title changed so that it's not too version-dependent. ;)
    Hope you didn't mind me moving this to a more appropriate section. :)
  9. 1k9
    Ok I'm trying it again and it seem good,
    I should disable gesture on Synaptic?
    It there a way to have glide
  10. MacHater
    You should, or Synaptics' software may randomly try to zoom, scroll, etc while you're trying to use two finger scroll.
    Not directly, yet. But you can use edge scrolling (continue scrolling when fingers on edge), which essentially does the same thing.
