Tv tuner for nx?
Discussion in 'HP' started by quesoyyo, Aug 28, 2004.
  1. quesoyyo
    quesoyyo Notebook Geek
    Does anybody know of any external TV-tuner I can connect to my nx7010 (via USB, f.ex.)? I'm going to college and TVs are prohibited where I'm gonna live.
    i was wondering if I could receive good quality TV with a TV tuner and if somebody could recommend me one.
    BTW, would I only be able to receive local channels? Which model do you own?
    HP Compaq nx7010, 512 RAM, PM 1.5 Ghz, 64 MB ATI 9200, 40 GB 4200 rpm, WSXGA (1680x1050)
  2. Venombite
    Venombite Notebook Virtuoso
    You can pretty much use any USB TV Tuner for your system. If possible, I'd get a USB 2.0 TV Tuner (ATI TV Wonder USB 2.0). This will allow for video to be piped into your notebook with minimal compression interference. Just make sure you get one that is compatible with your TV signal type (PAL or NTSC).
    A few brands that have USB TV Tuners:
    ATI
    Happauge (I think that's how you spell it)
    AverMedia
    You could also do a search in Google for USB 2.0 TV Tuner:
    http://www.google.ca/search?hl=en&ie=UTF-8&q=usb+2.0+tv+tuner&meta=
    -Vb-
    -Vb-
  3. quesoyyo
    So doesn't the TV tuner serve as an antenna? I mainly wanted it for use in countryside or in any other places where there aren't any antennas.
    I do not need it to transfer a signal from the TV to the laptop.
  4. Venombite
    You may have to hook up an antenna to the TV Tuner, but I believe that should be possible. The antenna should connect into the COAX connector on the TV Tuner.
    -Vb-
