turning off the led lights
Discussion in 'Gateway and eMachines' started by Tewka, May 22, 2009.
  1. Tewka
    Tewka Notebook Geek
    Ok I might be the only one but I hit fn+f1 and it turns off all the lights buuut.......the harddrive activity led. Is this normal? or better yet does anyone else have this strange occurrence?
  2. sparkyman2000
    sparkyman2000 Notebook Consultant
    Your normal....of course I had to check
  3. Kamin_Majere
    Kamin_Majere =][= Ordo Hereticus
    OMG your laptop is going to explode... i'm pretty sure i read that in the owners manual :p
    No its prefectly normal... i dont know any way (short of severing the wire to the light) to turn off the HD light.
    I guess Gateway wanted to let us still know the hard drives are working.:confused:
  4. maskedformed
    maskedformed Notebook Evangelist
    Does anyone know how to turn off the lights permanently (so they won't turn on after rebooting the laptop) instead of using fn+f1 every time the laptop boots up?
  5. t3rR0r
    t3rR0r Notebook Evangelist
    It would probably require much more effort than to just hit the button combination each boot up haha
  6. iaTa
    iaTa Do Not Feed
    Yeah, black electrical tape.
    Seriously though you could try disconnecting one of the ribbon cables which goes to the media bar. There are two and as long as you don't disconnect the power button. Wireless, numlock, capslock, HD, power lights may be a tad more tricky.
