Turning off blue led indicator lights?
Discussion in 'Dell' started by cell323, Oct 9, 2007.
  1. cell323
    cell323 Notebook Consultant
    Is there a way to disable the blue led indicator lights from being on, because they can become quite annoying at times. I am a proud owner of a Vostro 1400,
    Thanks
  2. 000111
    000111 Atari Master
    hehe... you could put a piece of tape over them. i don't know how to turn them off.
  3. lordnikon
    lordnikon Notebook Evangelist
    I find the blue LED light on my 65w AC adapter annoying. Its so bright it can light up a dark room.
  4. cell323
    hehe I'm trying to find an option other than covering with tape :p ;)
    Thank you though! Hope somebody knows.
  5. napalmb
    napalmb Notebook Enthusiast
    You could physically disconnect the LED wires if they are not soldered on.
  6. cell323
    thanks napalm, but i'm looking for a way to do it withing the software or bios.
    Maybe there is a program that I dont know of. I'm not looking to open the laptop itself.
  7. 000111
    000111 Atari Master
    just checked out the A03 bios. can't find anything that looks helpful there... it would be cool if notebook hardware control could do it, but i don't know if it can.
  8. cell323
    yeah it would be cool if at least it could make them dimmer at least. That would rock.
  9. capntang
    capntang Notebook Guru
    I doubt there's an easy way to turn them off via software. It's a case of function following form, I guess. I think Dell would have done better to use something other than superbright LEDs (who needs to see their laptop's status lights from two miles away?), or maybe they could have placed them above the keyboard so they could at least serve as a keyboard lamp.
  10. nizzy1115
    nizzy1115 Notebook Prophet
    the only way to turn them off is to unplug them.
