Turn on Wireless Capability?
Discussion in 'Networking and Wireless' started by Charles P. Jefferies, Oct 14, 2008.
  1. Charles P. Jefferies
    Charles P. Jefferies TG Lead Moderator Super Moderator
    Ok, I need some assistance here.
    I have a review laptop with Windows Vista 32. It was working fine on wireless up until this morning when it refused to connect to a different network (except for "Local" access) (the network worked fine on other machines). I did a "Repair" which somehow screwed the wireless, because now every time I go to connect, Vista says it can't find any wireless networks. When I click Diagnose, it says "Turn on wireless capability". However, the WiFi card is already enabled in the BIOS, the device manager, and even in the Network center. The laptop has no fn+Fx key combinations to enable/disable wireless, and no physical switch. I already uninstalled/reinstalled the device with new drivers and it didn't help.
    Any suggestions?
  2. John B
    John B Notebook Prophet
    Are you sure about the switch and FN keys? :p
  3. fonduekid
    fonduekid JSUTAONHTERBIRCKINTEHWLAL
    And I assume you have already tried manually connecting to a network, as well as 'manage wireless networks' and move the networks listed up / down the order in which vista attempts to connect?!!!! *Problem' for chaz himself???* talk about the ambulance itself meeting with an accident! :D :p
  4. Charles P. Jefferies
    Yup. The laptop came with a sheet that explained all the Fn functions, none of them can enable/disable wireless. There are no physical controls on the laptop to do this.
    Yes to those as well - there are actually no networks stored on the computer. I tried manually adding one, which did not work.
    Also, there is no antivirus/antispyware software installed.
  5. fonduekid
    Have u tried system restore to some point before this morning, before u started having this issue? *I guess you did!!*
  6. Charles P. Jefferies
    Alrighty, John B found there is actually a wireless control on it, the touch buttons at the top of it. Thanks John.
  7. fonduekid
    Ah good... finallY!!
    Btw, pssstt pssstt, what laptop is it? ;) :D :p *if only you had told me this, I would figured it out.. LOL... :D j/k Chaz.. anyway have fun with your review... :)
  8. John B
    We would have to kill you...lol ;)
  9. Charles P. Jefferies
    Alienware Area-51 m17x
    Review should be up in about a week.
  10. fonduekid
    Wow... Great! :)
    Alienware was my fav when I was hunting for a laptop, but then it was way too expensive for me right now :eek: so settled with the wonderful m1530.. Anyways.
    Love your reviews, Chaz.. and I'll be waiting for it :) Thanks.
