Tuning the Aero 15-w/x/v7/v8 - Common problems & solutions
Discussion in 'Gigabyte and Aorus' started by margroloc, Apr 27, 2018.
  1. AcerTimelineHunter
    AcerTimelineHunter Notebook Geek
    Nope, you'll have almost zero gain and after a long time end up installing what the laptop already came with.
    Except the software actually needed there is very little added by default, infact I have not found any...
    But, I ended up removing smart manager and do not miss the function keys, but my laptop feels a lot more responsive, no pointer lockups and not touch pad disappearing (thats a weired one) once smart manager starts :/
    Jo in short just remove what you don't like.
    2) modify the offset
    3)can and shoud be the same as core offset
    4)Minor undervervolt to integrated GPU won't hurt, like 0.07V
    bwanaaa likes this.
  2. Chris Marshall
    Chris Marshall Notebook Enthusiast
    I think I have a bad aero
  3. g85222456
    g85222456 Company Representative
    What kinds of problem you encountered?
  4. Chris Marshall
    I sent it back because I bought it off eBay and it was used. The heat was rediculous and the display would turn off and not come back. Gpu would not maintain any MHz. It would stay high after gaming.
  5. ReignsOfPower
    ReignsOfPower Notebook Enthusiast
    I've managed to find a set of RAM through my local Gigabyte distributor to match my stock set of V-color memory. Finally running a stable 32GB Dual channel setup. :)
    Anyone running dual DIMMs, have you observed increased CPU temperate when running dual channel memory configuration? My CPU seems to have jumped up about 5-10c as a result of the second stick of RAM.
    At the same time, I've added a 1TB Samsung 970 EVO drive and an Intel 9620 WiFi card. Everything working really well.
    Ross36 likes this.
  6. Chris Marshall
    What SSD / nvme should I get for 500GB and reducing heat / power usage from the stock SSD?
  7. headkaze
    headkaze Notebook Enthusiast
    margroloc likes this.
  8. grover_kiwi
    grover_kiwi Newbie
    Im running dual dimms, a Crucial 2666 set and no heat issues. I also put in the Samsung 970 1TB and about to use that as my main windows location, even though it will mean more hassle when reinstalled windows.
  9. grover_kiwi
    grover_kiwi Newbie
    I've had my Aero 15W for about a month now. I'm having problems with the USB ports. I sit mine on a coolermaster cooling stand, but I have to unplug and replug in the USB numerous times for it to start working. I also am trying to use a USB C displaylink monitor. It used to work but something recently has made it stop. I dont know if it was a bios update, I have tried FB06 and FB07 (I dont have anything earlier downloaded) but it just wont work, either through the USB C port or any of the USB 3 A ports, even with drivers. It works fine on every other computer. Thorugh the USB C port it does an error, and it wont even power on via the USB A ports.
    Anyone had similar issues?
    lmingll88 likes this.
  10. lmingll88
    lmingll88 Newbie
    Same here for a different USB A problem.
    Had mine for about a month. Updated drivers and Windows but I haven't done any BIOS updates.
    For the last week, the left one doesn't work at all.. I know that it worked before because I used an Oculus Rift on the left USB 3/A with the HDMI.
    I've turned off the USB-power-save mode, reinstalled USB hub drivers.
    But the left USB/A is totally dead. Tried keyboards, USB fan, mouse, hard drive, memory stick. Nothing.
    Anybody else?
