Tuning the Aero 15-w/x/v7/v8 - Common problems & solutions
Discussion in 'Gigabyte and Aorus' started by margroloc, Apr 27, 2018.
  1. DanielLong
    DanielLong Newbie
    Hey man, I have the same behavior on an Aero 15W with GTX1060. Therefore and also in order to improve battery life I set up the Control Center to use Performance mode when plugged in and use Power Saver mode when on battery. I also set the fan mode to quiet when I am on battery. This way the notebook is totally silent while browsing or watching movies. In my opinion the lower CPU (and be careful, usually lower WLAN) performance is not a limiting factor for such easy tasks.
    What you could also try is to use the Intel Extreme Tuning Utility and set the CPU TDP to 15-25W. As far as I know in quiet mode the CPU is anyway limited to 15W, but you can also play around manually. I often benefit from this setting when I play less demanding games and don't want to generate that much heat in Performance mode.
  2. DanielLong
    DanielLong Newbie
    I had almost the same issue: I used a decent quality USB3 hub for my mouse and keyboard and cooling pad. Only in Firefox I experienced the same freezing of the screen and sometimes my keyboard behaved like it would have been stuck in (i.e. asdddddddddd). However, for me the problem never happened in any other application, only in Firefox as I can remember. I have removed the hub which solved the issue in 90%, rarely I still have mouse freeze after clicking on a link.
    I will try to collect a USB-C hub as well and test it, would be great to have a solution.
  3. mojojojojoseph
    mojojojojoseph Newbie
    Anyone know where to get the LGD05C0 icm color profile?
  4. betaelmer
    betaelmer Notebook Enthusiast
    I just check and you can find the color profile such as LGD05C0 from SmartManager's color folder. On my laptop, it's under C:\Program Files\SmartManagerV4\color\P65\LGD05C0
  5. Shackles
    Shackles Newbie
    Did you have any success with a USB-C hub? This is driving me nuts...
  6. DanielLong
    DanielLong Newbie
    I have not bought any USB-C hub yet... I will share my experience as soon as I get one.
  7. jrmtz85
    jrmtz85 Notebook Consultant
    Started getting random reboots (Aero 15X V8) which take me to the BIOS screen with the following message:
    ROM image is not loaded. ROM image update denied
    They come at random times. Can be 2 days in a row, can go 2 weeks without one. Never seen the error happen. Just come back to the laptop having rebooted to that message. I always hit Escape, it asks me if i want to exit without saving, I hit yes, and then it boots normally.
    Any thoughts on how to fix? Running latest BIOS (FB0A) since October. Should I downgrade BIOS, reinstall current, try a CMOS clear, or something else?
    Thanks!
  8. DanielLong
    DanielLong Newbie
    I have bought a USB-C hub from ANKER (Amazon). Well, so far I haven't had any issue. However, I am a little confused, because I tried my previous USB (non-C) hub (ANKER as well), and now the notebook sometimes didnt want to recognize it... actually this hub seems to be faulty. Moreover, at my parents I tried a different hub, which also caused mouse lags in the past, but now it was OK. Maybe Windows updates fixed our issue? I will let you know if I have again the lagging with the new USB-C hub.
  9. Eduardo Torres
    Eduardo Torres Newbie
    I know it's been a while. I'm having the same issues and I haven't seen anywhere how to fix it.
    Did u manage to solve it?
  10. DanielLong
    DanielLong Newbie
    Hi!
    Well, first of all, I have never had any issue with the IDLE power consumption and my battery life has been always great but I will try to help you.
    I attach my ThrottleStop and Smart Manager settings. I have been always using the latest Smart Manager. I have never used custom fan profile. For normal daily activities I activate the Normal mode and on battery I usually set the Quiet mode. In ThrottleStop I have the same undervoltage preset for both battery powered and AC powered states. (UV is -130mV for both CPU and cache, see on screenshots). At the moment I apply a power limit of 20W, but before that I used the standard 53W without problem.
    In the Windows Power Settings, by default my active schema is the Smartmanager Power Saver when operating from battery. This schema is pretty much the default one from Gigabyte. In the CPU power settings the min CPU power is 5%, while the max is 100%.
    Let me know if I could help you.
    Sorry for all the Flickr ads, but this is the first time for me to post pictures with a 3rd party website...
    [​IMG]TS1 by Daniel Hosszu, on Flickr
    [​IMG]TS2 by Daniel Hosszu, on Flickr
    [​IMG]TS3 by Daniel Hosszu, on Flickr
    [​IMG]TS Options by Daniel Hosszu, on Flickr
    [​IMG]SmartMan by Daniel Hosszu, on Flickr
