Troubleshooting, Blinking Battery light on Inspiron 1150?
Discussion in 'Dell' started by alittlemonkish, Nov 30, 2008.
  1. alittlemonkish
    alittlemonkish Notebook Consultant
    What could be wrong with my Dell Inspiron 1150? troubleshooting blinking lights?
    http://www.jdmoutlet.com/1150_front_314x314.jpg
    That is my laptop. The three lights on the front from left to right. Power, Hard drive activity, Battery.
    The battery light is currently blinking in a pattern. 4 orange then 1 green in probably three seconds.
    Anyone know what the issue is?
    The laptop seems to be working just fine. The battery seems to be fully charged. It is on AC power. I can't find any issues???
  2. namaiki
    namaiki "basically rocks" Super Moderator
    How long can you run on battery?
    My Inspiron 4100 is like that and the battery lasts like 10 mins.
    I believe it means that the battery should be replaced.
    For me, it stops blinking like that when I remove the battery.
  3. alittlemonkish
    Im not sure but right now it says I have 98% left and 52 minutes. I just decided to check that myself right before i viewed your post.
    I will keep you updated...
  4. namaiki
    I think you might find something if you google the words: battery led blinking dell.
    I would, but dial-up is painful. :eek:
  5. alittlemonkish
    Well I'm back at I was just told by my computer to plug it in or it would die. So its seems that you are right.
    I ran it down to close to nothing today and it took a while to charge back up completely.
    So it seems that I have lost 2/3 of my battery life. It was close to an hour now it is 20 minutes...
