Trouble Overclocking 980m
Discussion in 'Gaming (Software and Graphics Cards)' started by kissof_Death, Aug 28, 2017.
  1. kissof_Death
    kissof_Death Notebook Enthusiast
    So i set a +100mhz oc on the core in afterburner just to start things off. I run msi kombustor (tessellated spheres x64, 1080p, AAx8) for about 10 minutes without a hitch. Temps top out at 74 and rest at 72-73 with no throttling. So next i try a game. I fire up dark souls 3 and not even 5 minutes into the game the video driver crashes. I've already unlocked the voltage slider but can only get an increase of 25mv. Not sure why i can make it through kombustor for but can't play ds3 for more than 5 minutes.
    Specs: Sager NP9758
    GPU: 980m
    CPU: i7 6700
    RAM: 8GB
    AC adapter: 220w (can buy a 330w)
    What do you guys think i should do. Should i flash with a modded vbios to fully unlock the voltage and power limiter, get a more powerful ac adapter since 220w might not be up to the task, or could have just had bad luck in the gpu lottery. As far as temps go i just ordered some ic diamond paste so that shouldn't be a problem.
  2. thegreatsquare
    thegreatsquare Notebook Deity
    Lottery mostly. My stock 980m 8GB [MSI GT72] can bench to +113/+92, but my gaming OCs are +0/+92, +56/+92 and +87/+92 as games get hit and miss after that.
    Vasudev likes this.
  3. Vasudev
    Vasudev Notebook Prophet
    If you have prema vbios then it can OC further.
  4. kissof_Death
    Where can I get prema vbios.
  5. Vasudev
    At the moment, the site is offline it will be online in couple of days.
  6. kissof_Death
    Is it the WordPress site
  7. Vasudev
    Yes.
  8. Carrot Top
    Carrot Top Notebook Consultant
    Keep in mind that synthetics like FurMark, Kombustor, and OCCT aren't a good test of overclock stability. You'll often find, as is the case here, that what's stable in those tests is not stable in actual games.
    They are also power viruses and not healthy for your GPU if run for an extended period of time, many people have killed their cards that way.
    Vasudev and Papusan like this.
  9. kissof_Death
    So what should I use? Just the game?
    Edit:Also can someone link me to another place other than tech inferno that has mNVflash. I cant dl anything from there.
    Vasudev likes this.
  10. Carrot Top
    Yeah real-world testing, like playing games, are best for determining OC stability.
    You can get nvflash from TechPowerUp.
    Vasudev likes this.
