Tried your 1520's headphone jack?
Discussion in 'Dell' started by EnderSaves, Jul 13, 2007.
Does your 1520's headphone jack transmit hard drive/internal laptop distortion/feedback?
  1. Yes
    244 vote(s)
    73.5%
  2. No
    88 vote(s)
    26.5%
  1. Stella
    Stella Notebook Deity NBR Reviewer
    I assure you, we are not. My headphone jack sounds like someone is sending a message via morse code, with loads of static laid on top.
  2. Badboi
    Badboi Notebook Enthusiast
    try using headphones with a gold plated connector!
  3. clester
    clester Notebook Enthusiast
    quite true stella. I get better sound from my wife's inspiron 6000 with it's crappy ac97 audio. the "HD" on the 1520 is completely ruined by the faulty hardware on the 1520. Very Disappointing. Don't want to have ro replace the lpatop, but i may be forced to if they can't fix it. Add it to the slower than advertised graphics card..
  4. Stella
    I already have a set of earbuds and a gaming headset that I really like--I just can't justify buying *additional* hardware to make up for faulty hardware. I'm hoping the problem will be fixed quickly in successive generations for the people that stick with Dell--it seems like just some extra shielding might resolve it.
  5. clester
    I can assure you badboi, that will make NO difference at all. all gold plating does is reduce oxidation on the jack itself. it won't fix a badly manufactured laptop motherboard.
    Oh and btw, i just looked.. ALL of my headphones have gold plated connectors. they all have the noise. it just gets quieter when the headphones impedance goes up. The worst for noise has the highest sensitivity, and the lowest impedance.
  6. davron
    davron Notebook Evangelist
    The included dell headphones are gold plated. They make the noise worse than my mp3 players' silver plated headphones.
  7. limagicman
    limagicman Newbie
    My situation is a little different. This system is in replacement of my two faulty E1505's that i received. I basically said that i wanted this card, and keep escalating me until i found someone who would give it to me. They called me back like half an hour later and gave me a dispatch number.
  8. Badboi
    well then i guess that was the fix for my d820.
  9. ColdSoul
    ColdSoul Notebook Consultant
    You can fix the issue if you turn on the option "run hlt command when OS is idle" in RMClock.
  10. clester
    While that works during the time that RMclock is running, the fact remains there is a problem. It still whines during boot up and shutdown, when Rmclock is not running.
    That to me indicates a problem, and should be fixed by the manufacturer/ retailer, rather than a fudged fix by the end user.
