Determination Bios v309 are @ 23.11.2o2o most recommendable: Example Reason v311 & v313 have reduced USB Power Values so after searching WWW i know why USB Dongle lossing connectivity :-( Standard Windows 10 power options: Minimum processor performance 5% Maximum performance state of the processor 99% = 1.7 Ghz - 4.2 Ghz slider taskbar middle or right 100% = 4.2 Ghz slider taskbar middle and right Performance increase mode for processors (only visible after registry tweak) High Adapted Windows 10 energy options: Registration change: Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\be337238-0d82-4146-a960-4f3749d470c7] "Attributes"=dword:00000002 Minimum processor performance 5% Maximum performance state of the processor 99% = 1.7 Ghz slider taskbar middle and right 100% = 2.9 Ghz slider taskbar middle and right Performance enhancement mode for processors Deactivated Legacy drivers and DCH drivers: Install Legacy Drivers Only or DCH Drivers Only! Radeon Control UWP can only be installed via the web link on the Asus driver webpage after the following forwarding to the Microsoft Store. At the moment the Realtek Audio driver is only available as a DCH version (in my case I had to find out that installing legacy drivers and the Realtek Audio DCH driver leads to extended boot times: in just 3 minutes PS: Stable working Drivers so far 0009-64bit_Win7_Win8_Win81_Win10_R282 Realtek HD Audio Fan starts to snort rather no bearing damage than the fact of the material expansion or PWM control AmaoryCrateService . . . yeah great tinkering announced ? Maybe someone will find other problems and their solutions.
This just added the option of Processor Performance boost mode ... and allowed me to select Aggressive. My 4800h is running at 4.2+Ghz pretty much constantly now.
Found RyzenAdjust which works similar to Throttlestop but via CMD (also no Installation only execute). https://github.com/FlyGoat/RyzenAdj https://github.com/FlyGoat/RyzenAdj/releases following ryzenadj-win64-release.zip Download and copy the files contained into a folder, e.g. RyzenAdj, then copy this folder e.g. to C: \ Programs. The included file demo.bat can be edited with Notepad. . . For me the content looks like this: %~dp0\ryzenadj.exe --tctl-temp=75 --vrmmax-current=75000 Tweaked Ugine Run CPU 4300MHZ - Max Temp & Noise @ 75 C° GPU 73 C° less Fan Speed The standard values for an Asus Ryzen 4800h in the Tuf A15 FA506IV can be validated with the HwInfo tool in the CPU tab (changed values are maybe not displayed ) Ungine stock Values CPU 4300MHZ - Max Temp & Noise @ 90 C° GPU 71 C° more Fan Speed %~dp0\ryzenadj.exe --tctl-temp=95 --vrmmax-current=96000 It have to researched the meaning of the values, but here is a table for orientation. Do not understand the values themselves sometimes crap happens ;-) --tctl-temp=95 | Temp Limit = Clockspeed Depending on Temperature . . . ? i Range 75 - 95 mayBe --stapm-limit=45000 | STAPM TDP = Watt ? --fast-limit=54000 | Long Boost TDP = Watt ? --stapm-time=900 | Long Boost Duration = Seconds . . . ? --slow-limit=60000 | Shorts Boost TDP = Watt . . . ? --slow-time=60 | Short Boost Duration= Seconds . . . ? --vrmmax-current=96000 | VRM Current (A) = Ampere / EDC . . . ? Real Noise Blocker Range 75 - 96 mayBe In Thesis some Values would work together with others so for Example: --tctl-temp=85 --vrmmax-current=86000 together --stapm-limit=45000 only as single Value Entry ( does set fast-limit & slow-limit @ 45000 Value ? ) --fast-limit=54000 --slow-limit=60000 together but values will revert to stock over short time ! A link to demo.bat, for example: create on the desktop and run. . . if necessary as an administrator. Ideally, let the demo.bat start via the autostart function when logging in after starting the computer or, if given, manually.
Also using MSI Afterburner to make an Performance-Curve Profil have Performance Boost and Power Improvment ( Secret Key Combo CTRG Left + F open Curve Window / CTRG Left + D resets to Default GPU Settings and also Shift-Key has Function ) . . . afer doing things in Right Table Window they are to ably in regeular MSI-Afterburner Window Left Important River Tuner has also to be Installed most Includet in MSI Afterburner Install package but is to Uncheck or Check . . . if not Download Riva Tuner Seperat ! i ! Example: Noise Block Stock Curve . . . Chose Quader by left mouse button press so that will be the new GPU Frequence Point mouse coursor lite behind marked quader press and hold left shift keyboard key press left mouse button hold and move mouse cursor to the right so present part behind will be marked Release left shift and mouse button and move cursor to first market then move down so all other entries move down under the chosen quader that will the new GPU Frequence chouse again new GPU Frequence quader and move upward Apply in MSI Afterburner main GUI Pictures are Examples mayBe 1560MHZ @ 0.725v or 1650MHZ @ 0.750v Stable values .
