Toughpad FZ-G1Mk1 and Mk2 screen swap and other parts.
Discussion in 'Panasonic' started by scpres, May 27, 2019.
  1. Shawn
    Never found any improved drivers for an iKey keyboard. I looked a lot.
    GPS on wwan is not a dedicated GPS module. The bios enables a dedicated GPS if installed.
  2. scpres
    scpres Notebook Geek
    That's right. But how come it wont recognise in gps viewer app?
    Because if gps is in the bios, then theres a gps installed right?
  3. Shawn
    Get into BIOS. F2 at boot. NOT PC Info.
    Go to the page with the ports listed. Advanced tab
    Click on the serial ports sub page. Serial ports line
    It should list serial port and GPS.
    If GPS is not listed there then you do NOT have a GPS module.
    Some photos are of CF31-G1 is similar
    20181218_210811-1024x1365a.jpg Screenshot-2019-6-4 Photobucket.jpg Screenshot-2019-6-4 Photobucket(1).jpg
    toughasnails and UNCNDL1 like this.
  4. scpres
    There is GPS AUTO in serial Port Setting... so why is it its not working in GPS VIEWER?
  5. SHEEPMAN!
    SHEEPMAN! Freelance
    Wyoming88! and UNCNDL1 like this.
  6. Shawn
    win10 needs a couple extra settings for a gps module.
    Cant recall 100% all of them.
    Jeff is correct about enabling location sensor.
    If you see gps auto in bios then you do have a gps module.
    Might not work on auto setting for the port.
    reading material
    http://forum.notebookreview.com/thr...s-cant-show-my-location.823417/#post-10801877
    http://forum.notebookreview.com/search/23128992/?q=windows+10+gps&o=relevance&c[node]=1012
    http://forum.notebookreview.com/search/23128994/?q=win+10+gps&o=relevance&c[node]=1012
  7. scpres
    I have CF-19 MK 6 and MK7 and they all have GPS module auto in Bios running latest windows 10 pro. They all work out of the installation no extra settings to be enabled. Its just weird the FZ-G1 doesn't work. Though the EM7305 has a gps sensor and I can navigate maps driving in micorosoft maps.
    Thanks for this.
    I will try because I don't have skylight sierra installed in FZ-G1 but I just had a look of my Motion R12 which has the same sierra module installed and the motion R12 has a NMEA sierra in device manager with skylight installed?
    Where can I get the software for FZ-G1 or can I just use the one for my motion R12 rugged tablet software?
  8. scpres
    this is the device manager of my Toughbook CF-20. The nMEA is not showing on my FZ-G1.. I think by installing the skylight software it will wok,, need to try later after work
  9. Shawn
    Pick one gps system to work with please.
    Bouncing between wwan and dedicated gps is like mixing eggs and watermelon.
    wwan /sierra gps is different than a dedicated gps module ( serial port in bios)
    Each requires different software and different settings.
    Sierra skylight has nothing to do with dedicated gps, however it may work with wwan based gps.
    UNCNDL1 and toughasnails like this.
  10. scpres
    I scored a 40 Hour Toughpad FZ-Y1C im so happy!!!!!!
    toughasnails likes this.
Similar Threads - Toughpad G1Mk1 screen
  1. scpres
    445
