Toughpad FZ-G1Mk1 and Mk2 screen swap and other parts.
Discussion in 'Panasonic' started by scpres, May 27, 2019.
  1. scpres
    scpres Notebook Consultant
    Hello
    I have an mk1 and mk2 toughpad fzg1. The mk1 won’t boot up as motherboard is faulty it’s in excellent condition and I have an mk2 that boots up but in very bad condition. I want to swap the parts from mk2 to mk1 body. Any help please. Even if I just change the screen of mk1 to mk2 and the fan as well as the one in mk2 is very dirty.
    Thanks.
    I will upload the pin connector of screen in mk1 as I don’t know how to remove it.
  2. UNCNDL1
    UNCNDL1 Notebook Deity
    Ultimate Search Ninja has been inside several G1’s modding like crazy ...hopefully he will have some answers soon...
    Sent from my CF-M34
  3. Shawn
  4. scpres
  5. Shawn
    I don't know if you are swapping screens or entire housing or what for sure.
    You bounced around a bit.
    Screens should swap.
    Housing may not work. Motherboard and heatsinks are quite a bit different.
    You need to compare both units side by side.
    Proceed carefully as the housing / motherboard removal is detailed. Heat sink pads WILL need to be replaced. LCD cable connector ends break easily.
    UNCNDL1 likes this.
  6. scpres
    I will only swap the screen as I don't want to complicate things.. a bit hesitant regarding the cables though how to remove it?
  7. Shawn
  8. scpres
    Thanks for the reply. It was a success and I'm currently using it now. It's fast and awesome in windows 10 x63 v1903.
    Just a question though, there is a GPS which is enables in the bios? Where can I see the drivers to get it working in GPS viewer?
    Cheers
  9. Shawn
    You need the gps module to make that work.
  10. scpres
    Thanks.
    I thought it has already a GPS inside. Its wwan has a gps built in so I can navigate via map. Its awesome in windows 10.
    I havea keyboard key from ikey. Do you know if there's any drivers available for that so the TouchPad can work like scrolling on the side. Because its pretty basic
