Toughbook quiz for fun
Discussion in 'Panasonic' started by Shawn, Jul 7, 2018.
  1. Shawn
    The page is interactive.
    https://www.proprofs.com/quiz-school/story.php?title=panasonic-toughbook-knowledge-evaluation
    Questions and Answers
    • 1.
      Which of these componenets can be easily removed from the CF-74 by simply releasing a latch and sliding?
      • A.
        Hard Drive
      • B.
        Memory
      • C.
        Wireless Card
      • D.
        I/O Panel
    • 2.
      The Panasonic Diagnostics tool can be accessed at the splash screen by pressing:
      • A.
        F7
      • B.
        F2
      • C.
        Ctrl+F10
      • D.
        Ctrl+F7
    • 3.
      What are the main types of screwdrivers needed to work on these units?
      • A.
        Phillips 0, 1, 2
      • B.
        Hex
      • C.
        JIS (Japanese Industrial Standard)
      • D.
        None of the above
    • 4.
      The Hard Drive is held in encased foam via:
      • A.
        Hooks
      • B.
        Screws
      • C.
        Ties
      • D.
        None of the above
    • 5.
      The difference between a high and low end model is:
      • A.
        Hard Drive size only
      • B.
        Memory and Hard Drive Size
      • C.
        Processor and screen resolution
      • D.
        None of the above
    • 6.
      The term "Mark or MK" of a Toughbook model indicates in which revision or generation the unit was manufactured:
      • A.
        True
      • B.
        False
    • 7.
      The CF-52 Model has an option for a fingerprint reader:
      • A.
        True
      • B.
        False
    • 8.
      The CF-74 has a blinking orange battery indicator. This means:
      • A.
        Low Battery
      • B.
        Problem with battery
      • C.
        Charging
      • D.
        Out of temperature range
    • 9.
      To remove the ROBSON cover on a CF-52, you will need a:
      • A.
        #1 JIS cross-head screwdriver
      • B.
        #2 JIS flat-heat screwdriver
      • C.
        Secure Torx T7 screwdriver
      • D.
        None of the above
    • 10.
      On a CF-73, the wireless LAN module is located on the main board:
      • A.
        True
      • B.
        False
    toughasnails likes this.
  2. BaRRmaley
    BaRRmaley Notebook Deity
    Panasonic's engineer doesn't know correct answers and tries to get a free help that way.
    toughasnails and Shawn like this.
  3. BaRRmaley
    Questions part 2 :))
    Here is fz-g1 with serial port. If we try to change that option to ethernet port - no signs of the installed option neither in bios nor in windows. Do we have to change optional kit config code or something like that? Power reset doesn't help. Thanks.
  4. EdFromBJCS
    EdFromBJCS Notebook Geek
    All questions are about the CF-74, CF-52 and CF-F8. What a strange sampling.
  5. Shawn
    Just like the members of this board...
