Toughbook CF-30K
Discussion in 'Panasonic' started by tvb2727, Jul 21, 2011.
  1. tvb2727
    tvb2727 Newbie
    My COA says: Windows Vista Business. So the Recovery DVD's should work? Probably not a bad idea to have them anyways.
  2. toughasnails
    I have never had any problems when I use the restore disk and it only takes about 30 minutes :D
  3. TopCop1988
    TopCop1988 Toughbook Aficionado
    Grab `em quick!
    Panasonic CF-30 Toughbook Recovery DVDs
    2-DVD set delivered along with a Toughbook CF-30 laptop computer. Still in unopened sleeves.
    These DVDs came with a laptop with model number CF-30K
    ○ factory original discs, with OS and drivers.
    ○ Disc Labeled: Windows XP Professional SP 2 MK3-XP2M
    ○ Disc Labeled: Windows Vista Business SP 1 MK3-VB1M
  4. toughasnails
  5. John229
    John229 Notebook Geek
    Check BIOS to see if there is a SATA native mode and disable it. Win 7 and Linux have the drivers to support it. I've run into this with installing XP on various laptops with SATA. The best way to get the OS is via a Recovery Disk as the required driver(s) have been patched in. ;)
  6. tvb2727
    tvb2727 Newbie
    Well, bought me a CF-30k restore disk and everything is working perfectly now. It restored everything without any issues. Thanks again :)
  7. TopCop1988
    As always, the factory Panasonic Product Recovery Disk Set is worth the money! :)
  8. toughasnails
    Well a little late now but I think that in order to run XP on a CF-30 MK3 you need to downgrade the bios. On the MK1 you have to upgrade the bios for vista /w7 but if you put XP back on you must down grade the bios. Maybe that was the problem.
    update:
    That is only required on the MK 1 and MK 2 versions , thank you Rusty for the info.
  9. John229
    Well, I haven't worked on any TB with a SATA drive, but the five 'Other Brands' laptops I have that were SATA equipped had issues that ended up either using a restore disk for that make and model (best option) or changing the SATA mode in BIOS.
  10. rjenkins
    rjenkins Notebook Consultant
    I had exactly the same thing recently.
    I found the appropriate SATA install driver, but could not get it to both boot and install using a USB floppy for the driver disk.
    I ended up adding the driver to the XP SP3 OEM disk I was installing, using 'nLite'.
    That then installed perfectly.
    I did not want to change anything else on the machine, as the whole point was to be able to swap between W7 and XP by exchanging hard drive caddies.
