touchpad scroll does not work
Discussion in 'HP' started by thinkwierd, Jan 29, 2007.
  1. thinkwierd
    thinkwierd Notebook Evangelist
    Synaptics is running now but the scrolling function of touchpad does not work anymore.
    Anyway to enable it? what is going wrong?
    ps. new machine and the touchpad worked just now.
  2. Strawbs
    Strawbs Notebook Guru
    Go to Control Panel>Mouse>Device Settings>Settings to make adjustments to the tracking areas of the touchpad.
  3. TheMan
    TheMan Notebook Consultant
    Call up HP (good luck with that!) tech support and ask them what should be enabled for it to work. If you turned it off in MsConfig then it won't work.
    Start > Run > msconfig > I'm not sure which driver it is, so call up HP and find out.
