Toshiba Satellite L505-S5998
Discussion in 'Hardware Components and Aftermarket Upgrades' started by garfield1101, Oct 7, 2017.
  1. garfield1101
    garfield1101 Newbie
    What other ram cards can I use in a Toshiba Satellite L505-S5998
    I has PC2-6400S and they cost too much to buy.
    It has a Max amount of 8GB it can have it in.
    What other PC2 ram cards can I use? I need to find cheaper ones.
    8GB of PC2-6400S cost more then the laptop did.
  2. tilleroftheearth
    You can try any DDR2 RAM you can find cheaply. No guarantees what may work with your M/B, BIOS and CPU though.
    What do you have in it now (capacity)? What O/S are you running? What workloads do you expect to do with this system?
    Depending on your answers above; 8GB of '6400S may be worth it - even if it more than doubles the purchase price of the system (btw, what did it cost you?).
