TONGFANG GK5CN5Z and TONGFANG GK5CN6Z
Discussion in 'Other Manufacturers' started by sicily428, Apr 22, 2018.
  1. Nap0l3on
    Nap0l3on Notebook Enthusiast
    WoW here is my CB results, very similiar results on my config. (TG Kryonaut and Artic Thermal Pad 1.5mm, max 83C - stress test (cpu+vga) )
  2. Turnip
    Turnip Notebook Enthusiast
    So I've had my laptop for about 2-3 weeks now and while I've ironed out basically all my issues, I noticed something today that is now bugging me because I don't remember if it was here before or not.
    I have the 144hz screen and I've just now noticed there is a thin black border around the screen. They persist even when its turned off - I can still see the color difference. It's more of a cosmetic slight really, and seems like these should be covered by the bezel, but I just wanted to confirm if anyone else had this as well? To see if its the actual border of the panel itself or if I have some other issue that just popped it. It just seems strange that I wouldn't have noticed it up until this point.
    Edit: I've already stopped noticing it so it probably has been here the entire time.
  3. steberg
    steberg Notebook Evangelist
    I'm running on XMG bios now; it's EC v.1.29.09 and Bios v.1.03. Nice XMG boot logo.
    I also installed Premas latest ME firmare 12.0.3.1091
    Got 1211 in CB. The best from Mechrevo bios 1.10 was 1216
  4. Phoenix1221
    Phoenix1221 Notebook Geek
    Thanks for posting your results lads, it's always good to have something to compare too. I use the Mechrevo 1.10, think EC version is the same as yours. I'm getting around 1210-1220 with ThrottleStop settings finetuned.
    Sent from my SM-G950F using Tapatalk
  5. lKinder_Bueno
    lKinder_Bueno Notebook Guru
    Mechrevo uses 1.23.09 EC. So the XMG is the most updated
    Nice! I can't wait to test it when PCS will send back my laptop after RMA
  6. Phoenix1221
    Thanks for clarifying! I wonder if there's any significant difference between the EC versions. I like to keep my stuff updated but everything works and I'm getting good Cinebench scores so I might just leave it until there is a bigger step forward.
  7. OliverL87
    OliverL87 Notebook Enthusiast
    @lKinder_Bueno
    How did u flashed it? Did u do it on the Windows Desktop?
    Like there?
    http://tieba.baidu.com/p/5726872551?pn=0&&red_tag=b2566302235
  8. Nap0l3on
    NO. You can easily turn your laptop into brick i guess.
    My methode:
    Use EFI shell (boot from Pandrive):
    Update the BIOS and then the EC.
    Code:
    First: AfuEfix64.efi ROMNAME /p /b /r /x /l /reboot
    Second: AfuEfix64.efi ROMNAME /p /b /r /x /l /capsule
    (If I remember correctly)
    Be careful! Easy to brick from your laptop!
    steberg likes this.
  9. damole
    damole Notebook Geek
  10. lKinder_Bueno
    Download BIOS file from PCS, put the two folders on the USB storage and follow the instructions
