Thunderbolt 3 eGPU solutions arriving 4th quarter 2015, mainstream in 2016
Discussion in 'e-GPU (External Graphics) Discussion' started by kousuke, Jun 6, 2015.
  1. sicily428
    sicily428 Donuts!! :)
    AORUS GTX 1070 Gaming Box Overview
    Gigabyte AORUS GTX 1070 Gaming Box Review
    hmscott and Starlight5 like this.
  2. Maru
    Maru Notebook Consultant
    Apparently at SIGGraph'17, NVidia announced a program to certify external GPU interfaces either for Titan XP, or for Quadro GPUs.
    I wonder whether this means they will also certify laptops and mobile workstations.
    Or whether each eGPU certification is restricted to certain pairings of laptops tested with that eGPU.
    (And will they also certify All-In-One and small desktops with TB3. Or even iMacs, helping NVidia with other eGPU makers compete with the Apple External Graphics Development Kit, a Sonnet eGPU & AMD Radeon RX 580.)
    hmscott and sicily428 like this.
  3. sicily428
    Clevo N750HU/N751HU
    http://www.clevo.com.tw/clevo_prodet...d=1041&lang=en
    with a 4-cores cpu HQ and IGPU [​IMG]
    Key feature
    7th?Generation?Intel®?Core™?processor
    Expandable DDR4 memory up to 32GB (depends on RAM module)
    ODD design
    Support Caddy Bay
    White-LED illuminated keyboard (option)
    One USB 3.0 port or (option) Thunderbolt 3 combo port support eGPU Box (Type C)
    M.2 LTE or UMTS/HSPA+
    __________________
    hmscott likes this.
  4. Nirosh B
    Nirosh B Newbie
    I bought a laptop from PCSpealist in the UK, with custom built hardware.
    Chassis & Display Octane Series: 15.6″ Matte Full HD IPS LED Widescreen (1920×1080)
    Processor (CPU) Intel® Core™i7 Quad Core Processor i7-6700k (4.0GHz) 8MB Cache
    Memory (RAM) 16GB HyperX IMPACT 2133MHz SODIMM DDR4 (2 x 8GB)
    Graphics Card NVIDIA® GeForce® GTX 1060
    Power Supply 1 x 230W AC Adaptor
    USB 1 x USB 2.0 port
    3 x USB 3.0 ports (USB 3.1 Gen 1 Type-A)
    1 x USB 3.1 Gen2 port (Type-C)
    1 x USB 3.1 Gen2 port (Type-C) Thunderbolt Combo Port
    Thunderbolt Yes (via USB 3.1 Port)
    So is this laptop support this eGPU enclosure
  5. sicily428
    Is it an octane?
  6. Nirosh B
    Nirosh B Newbie
    Yes..Octane with Clevo Bacborn
  7. sicily428
    A user of this forum used a p750dm with an egpu so that p750dm2 should be compatibile
  8. sicily428
    @Nirosh B
    you can also replace your gpu with a mxm gtx1070
  9. Nirosh B
    Nirosh B Newbie
    Thanks for the quick reply.Now I do have one Thunderbolt port on my laptop,so if i want to add couple of GPU card on my eGPU,which means do i need more TB.ports.
  10. Nirosh B
    Nirosh B Newbie
    Yes..but mostly i'm doing 3Drendering stuff with GPU rendering,that's why i looking for eGPU system
