ThinkPad X1 carbon disable power internal battery to replace SSD
Discussion in 'Lenovo' started by zillah, Jun 29, 2018.
  1. zillah
    zillah Notebook Enthusiast
    Dear Experts
    I want to change SSD for ThinkPad X1 carbon to a bigger size , I need to disable power for the internal battery first
    I tried to follow (pressing F1) :
    https://pcsupport.lenovo.com/au/en/solutions/pd025206
    F1 didn't work for me, I pressed Enter then F1 then Ctrl + S
    But I can't get to the Config option ,,,,I am not sure why that is happening ?
    Please see the snapshot what i am getting
    https://imgur.com/a/YkGP8m4
    Thx
  2. Mobius 1
    Mobius 1 nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ⎬⎛⎝⎠⎞⎨
    I didn't disable the internal battery and did a repaste and ssd swap, no damage.
    You can physically disconnect the internal battery inside the machine if you so desire.
  3. zillah
    Was try trying to follow the procedure as mentioned when I did google research
    I struggle to do it as this is a trick to push battery little bit to disconnect connectors and I couldn't find my my laptop model ThinkPad X1 carbon 6th
  4. Mobius 1
    You can find the HMM instructions here: https://thinkpads.com/support/hmm/hmm_pdf/x1carbon_2_hmm_en_sp40a26110_01.pdf
    Honestly I wouldn't even bother with disconnecting the battery. Just shut it down, open the panel, swap the ssd, then close the panel.
  5. zillah
    Thanks Mobius for your advice and appreciate your help
  6. Grant B Gibson
    Grant B Gibson Notebook Deity
    Disconnecting the battery isn't entirely necessary for something like this, but doing a repaste, I wouldn't take the risk
  7. shengna
    shengna Notebook Consultant
    I never disconnected battery before swapping ssd. Shouldn’t matter in my opinion.
