Thinkpad T470s fan behaviour
Discussion in 'Lenovo' started by kuschi, Oct 10, 2017.
  1. kuschi
    kuschi Newbie
    Hello,
    i recently got a Thinkpad T470s. I would be more than happy with it if there would not be that issue with the fan. When its idling it is turned off. But when i start browsing and open some tabs (f.e. Youtube, Amazon, etc.) the fan turns on pretty fast with almost the highest speed. It is pretty loud and it howls when im just surfing. Sometimes the fan speed decreases a bit, but opening a new tab it turns high immediatly. So in some cases it is an up and down - pretty annoying. Doing more/heavier tasks than just browsing the fan sticks at highest speed und howls.
    Anybody else here having the same behaviour with its T470s?
    I updated everything(BIOS, drivers, etc.) and checked energy options but nothing helped. I mean i already read in reviews that the fan turns on pretty fast, but i was not expecting something like this.
    Is this normal or did a get a defect model? Could it be that Lenovo installs other/louder fans in models with lower specs?
    The notebook has following specs:
    -Type 20HG
    -I5-7200u
    -512 GB, SSD, PCIe-NVMe
    -8GB RAM
    -Windows 10
    Thanks & best reards!
    Mobius 1 likes this.
  2. Mobius 1
    Can you monitor the system temps while you try to replicate the issue?
  3. kuschi
    kuschi Newbie
    Hello,
    thanks for the reply!
    So i currently made some screenshots when the fan started.
    https://postimg.org/gallery/mf6rs93w/
    When it did i executed the sensors command twice immediately.I n all cases the fan turned at a pretty high speed and then turned off after some seconds. Typing or loading a new page causes the same again. Turning on and off, on and off...
    In the 3. picture you can see that the temp rised while loading notebookreview.com.
    I mean it is ok that the fan starts when the CPU has some work to do, but turning up that loud and the howling.. Especially increasing the fan speed from 0 to almost 100% and after some seconds turning off or slower until you click a link or just type something seems not normal to me..
  4. Mobius 1
    Can you please imgur the screenshot, postimg isn't working very well for me.
  5. kuschi
    kuschi Newbie
  6. Mobius 1
    And you are sure the bios is updated to latest?
    The temp are all below the active trip point too. My X1C5 only uses the fan when cpu is around 65c.
    So I'd guess it's either you need cmos reset, a bios update, or there is something wrong with the heatsink (seems unlikely).
  7. kuschi
    kuschi Newbie
    Yes i updated everything to the latest version and did a cmos reset alreay.
    It seems that the CPU gets temperature peaks over 65c opening a new page or doing some other stuff what causes the fan to start. But anyway turning at full speed is not what i expected.
    I think i will send it back now..
    Thank´s for the help!
  8. VitMosin
    VitMosin Newbie
    Hello. I have the same problem with t470 model. Did you solve it?
  9. GP-SE
    GP-SE Notebook Consultant
    same issue here with an Ideapad 720s
    if you check the official Lenovo forums lots of people have this issue (with the ideapad 720s)
  10. GP-SE
